- Joined
- Jun 29, 2016
- Messages
- 157
Hey everyone, it's spring and it's time to get to work, so I'm getting ready to go the next step on the audio on Ol Yeller (See https://wranglertjforum.com/threads/2000-tj-ol-yeller.1791/#post-28765 for build thread). The head unit and speaker replacement went great, and has 'helped', but since I have no plans on putting sound deadener in the tub, the answer needs to be MOAR WATTS.
What I'd like to do is add two new amps (75w RMS at least each). One for the front speakers, one for the rear. I suspect I'll do a subwoofer at some point, but I can drive that off one of the amps.
Here's the questions.
- Where the HECK do you put amps? I can probably fit them inside the console behind the head unit, but that's going to be cramped and I'll need to rig up a bracket of some sort
- I'd really like to put a set of tweeter pods on the dash, and use either the amp crossover, or the JVC head unit crossover to drive them. The main question is how to wire this. Do I get a 4 channel amp for the front speakers, and put a passive crossover in line to the tweeters? This seems like the easiest solution.
- A subwoofer will balance out the tweeters nicely. My TJ does not have hte center console mount for the sub - has anyone ever retrofit one? Or should I get a sound box for the rear and use that?
