That's a great end to your day!Been a while since I've been on here. Have done rear brakes, calipers, front brakes, calipers, the whole 9 yards. All went fairly smoothly.
Also, I've had a chirping sound when pushing in the clutch pedal at idle, so decided to refresh everything in there. Good thing too, as the TOB was real close to failing. Didn't seem as if there was any grease left in the bearing-I could spin it by hand but as soon as I took my hand away it would stop moving--so I got lucky I got to it before it failed. Should note that my (probably stock) clutch and flywheel looked really good for 150k miles.
So anyhow, first time doing the clutch so it takes me 6 or so hours, put everything back together, start her up, put it into reverse and... nothing. I can Rev it but it seems like something isn't engaging. In between cursing and trying to figure out what went wrong or if I somehow put the clutch in backwards, I look down and realize that the T-Case shift lever had somehow found its way into neutral when I was disconnecting and reconnecting the linkageSo popped it out of that and drove off. The jeep shifts noticeable more smoothly and is noticeably quieter now!
