So I have this idea. EV is changing the car world, but it hasn’t appeared in the off road world yet, to my knowledge. As we all know, our TJs aren’t the best on gas, especially lifted and with tires. I get 14mpg highway on 35s and a 4in lift.
to address this issue, I’ve been thinking of creating a series hybrid drivetrain to increase MPG and torque. Both of these things would increase off road performance. Imagine being able to tap into 100% tq on the trail at all times.
I see several advantages right out of the gate here. The need for axels, axel tubes, differentials, transmissions, transfer cases, and lockers would be totally unnecessary. It would all be controlled on the hubs by electric motors and software.
For those who don’t know, a series hybrid uses an internal combustion engine (referred to as ICE for the remainder of thread) to power a generator that powers the motors and charges the battery bank when needed. This means the ICE doesn’t run full time, and only runs at its most efficient RPM when it does. The batteries power the motors and relies on the ICE to be charged when needed. A parallel hybrid still has an ICE that is attached to the drivetrain which lowers its efficiency.
I will have to dyno my Jeep to see how much power and TQ it currently makes to source a generator of equal output, but standard power use of a vehicle is 15-20kw to move on a series hybrid design.
With that said, to get the most efficiency, you’d want to upscale that number to reduce fuel consumption, so I’m thinking a 30kw diesel generator. This would consume 2 gallons an hour on a generac diesel generator. So in theory, at highway speeds (70mph) that would be 35mpg. Or over double my current fuel consumption at a minimum if the engine runs all the time, which isn’t how the system works.
Now that we have the benefits listed, to a somewhat degree, it would only be fair to discuss the drawbacks.
I would have to design a custom hub at each wheel to hold an electric motor, suspension mounts, sway bar mounts, brakes, wheel bearing, and studs. This is if I wanted to totally delete the axels and axel tubes. Cost is another issue, as generators are not cheap and neither are batteries. System management would rely on a MoTec ECU as they offer hybrid support, but that is also expensive, but it comes totally customizable with traction control support as well (lockers and LSD for daily use). Weight would also be a factor as subtracting an engine, trans, and transfer case would be replaced by a generator and a battery bank; neither of which are light. The weight may be offset, or it will increase.
All in all, I think it would be a fun project and be the first of its kind. If desired I can site a thesis paper on EV.
