No wheel hop at all I suspect the metal got tweaked during the tub removal. Didn't have enough attachment points. Now here is a Throttle Body!View attachment 1599
I assume the wiring was the worst part of the swap?
Nope. Novak provided a plug and play wiring harness. Worse part ws debugging about a dozen codes that kept getting thrown.
What kind of codes was it throwing? Were those codes boogers to solve or what?Nope. Novak provided a plug and play wiring harness. Worse part ws debugging about a dozen codes that kept getting thrown.
Actually there are quite a few companies making harnesses. Tell them the setup info and get a harness AND most also will tune your ECM for you. Best source for this specific kind of information is Pirate 4x4 —-If you can put up with condescending BS.WHAAAAAAA!? I didn't even know they made one... Good lord... Now I am considering this swap even more knowing this.
The codes were all over the place mostly due to emissions related stuff. However the ECM that came on the donor truck was a E78. That would not work with the tach stuff from Novak. They sourced and tuned a E38. There in laid the problems. The older E38 had a software change some where around 2012 and the used E38 they had didn't have new software..........................My rig now thinks it is a 1 ton Chevy van iIts a long and expensive story so the short of it is this was one of the first Gen IV engines with a 6L90 that Novak had done. We all had a learning experience.What kind of codes was it throwing? Were those codes boogers to solve or what?
Duan, the only way to make more HP is to burn more fuel and air mixture.
..aaand, I don't think that the ECM for Jeep motors are re-mappable. (Is that even a word?)Too true. Additionally, if you're pulling more air, the only way to get more fuel is to remap your ECM.
I dunno, I had no idea what the rhetorical part was doing mixed up with that question so I just answered what I thought was a legit question.What part of rhetorical was missing? I know that and apparently missed being funny.
I dunno, I had no idea what the rhetorical part was doing mixed up with that question so I just answered what I thought was a legit question.![]()
Ok, ok. I lost the funny part of this thread. My 05 manual tranny has(d) a PCM with three ports. The Automatic versions have a PCM with 4 ports.
Now my V8 jeep still has a PCM (power control module) with three ports it runs stuff like gauges, speedo, 4x4 on, lockers engaged, seat belts.etc. I also have ECM (engine control module) but the TCM in intrinsical to it. So all the engine, tranny stuff is controlled by it.
