Was the 9 pieces only used up only in the tub (behind the front seats) or was it enough for front half too ?
It was enough for 85% coverage of the tub front and rear. The front was in a post yesterday :)
Reactions: Kiwi TJ and Alex01
When sound deadening material like that is put down, how hard is it to remove if a situation came up where you needed to get under it?
Just curious, I've never dealt with any of that stuff. I always wonder about water getting trapped under it and causing problems.
Reactions: Fouledplugs
It would be moderately hard to remove from what I can tell. And I don't think you'd be able to reuse it. As far as access goes I cut around any service areas drain holes, bolts etc.
I’ve been keeping track of it for a while, and everything is good except for around the skid plate. There is flaking on the inside on both sides, so I’m gonna replace them pretty soon. I already did the driver’s side rear trailing arm a couple of years ago. I eventually want to do a frame swap, but I’ve got to save up for it, and find one that is in decent shape.
Go down South, Texas, Arizona, or even SoCal.
Reactions: HBomber8
Looks great! This is my next order, was trying to find a used set, damn they are high on the TJ's!
I think it's a hard item to find used since you only need to replace the MORryde if you size up to a 37+. Mine took about 4-5 weeks to show up so I'm guessing the demand is high. I've only opened the trunk a handful of times with it so far but it is leaps and bounds easier than the tire carrier. The wife and 12 year old can now get into the truck without any assistance.
Reactions: DrDmoney
I think it's a hard item to find used since you only need to replace it if you size up to a 37+. Mine took about 4-5 weeks to show up so I'm guessing the demand is high. I've only opened the trunk a handful of times with it so far but it is leaps and bounds easier than the tire carrier. The wife and 12 year old can now get into the truck without any assistance.
Really ? I've got 35 and figured I would need to add this to carry a 35 spare?
OMG....is that a "killer" Hi-Lift jack on the front of her Jeep?? Just kidding, I just had to say that with all the Hi-Lift haters :). I have one on the back of mine as you probably already know.
As do I, Her Jeep actually came that way, and I offered to take it off, but she said she liked it so it stays. Haha
