Oh boy,
What I'm suggesting is going to be considered sacrilege to so many people!
This idea hit me last night and I haven't been able to stop thinking about since it got in my head. So for those of you who don't know I own two Wrangler's currently. A stock 2005 LJ Rubicon that I got for a steal in February and a 2006 Right Hand Drive TJ that I got back in 2017 that I've been doing a Kubota diesel swap into.
Currently the RHD TJ has a 1.25" body lift, 31.7 pizza cutter tires (235/85r16) and I've managed to tuck the entire drivetrain above the bottom of the frame-rails. It has a NorthWest Fab Doubler and an AW4 automatic transmission as well. This is going to be my offroading/overlanding rig.
My 2005 LJ Rubicon is basically my Wrangler to pickup my kids and go get groceries. It's bone stock, new soft top, new tires, and a manual NSG370 6-speed transmission. I don't mind driving it on the road but it's not my favorite driving offroad. I really prefer driving an automatic offroad!
SO here is where my idea hit. I'm planning on going to Moab next year and have been told having lockers in my axles would be a benefit. Also right now I feel like I'm revving the heck out of my 4.0l driving my LJ Wrangler around.
Currently my RHD TJ has a Dana30(Open)/Dana44(LSD) with 3.73 gearing. My LJ Rubicon is Dana44(Selectable Locker)/Dana44(Selectable Locker) with 4.10 gears. My RHD TJ has a NP231 that has been upgraded to a super short SYE that will plug into the factory harness as well.
If I put my axles from my RHD TJ into my LJ, I drop all my cruising RPM so I'm not revving my engine as much. My 65mph RPM would go from 2469rpm to 2246, my 55mph would drop from 2089rpm to 1900rpm.
If I put my axles from my LJ into my RHD TJ, I would put my cruising speeds at 55mph and 65mph within the ideal power band of my diesel engine. My AW4 has a 0.70 overdrive ratio which is much lower than my NSG370 which has a 0.85 overdrive. So with my current axles in my RHD TJ 55mph would be 1521rpm just barely in the ideal power band for my diesel engine. However if I swapped in the 4.10 Dana 44 axles my rpm at 55mph becomes 1672rpm which is right where you want the diesel to run. Same with 65mph as well, it increases from 1797 to 1975, but I can accelerate from 55mph to 65mph without having the transmission to downshift.
As for the transfer cases, I'm never going to really use the low range on my LJ Rubicon currently. I might stick it in 4-Hi if I'm moving around my yard or something but I'm never going to need the 4:1 low range in it. However in my RHD TJ, YES I have the doubler, but really that gives me 1:1, 2.72:1 and 7.4:1 ranges! Not bad at all. HOWEVER if I swap in my NP241OR into my RHD TJ I would have the following gearing available to me 1:1, 2.72:1, 4:1, and finally 10.88:1
Also thinking about it, the rear Dana 44 in my RHD TJ is a Limited Slip which if I put it in my LJ which I use to pickup my kids and get groceries is better suited for driving on the road in bad weather conditions as I have more tractions compared to the unlocked Dana 44 thats currently in it.
To further add to all of this I've thought about making my LJ Rubicon into a pickup truck for towing my CJ-2A once I get it built and having an LSD in it works wondering for towing. I have a LSD in my Diesel Liberty right now and it's been great for towing in the rain and slippery conditions.
I know in an ideal world I would just pickup a set of Rubicon Axles and another NP241 transfer case but even if I got a smoking deal on all three, I would be looking at $4000 if I was lucky.
Am I just completely crazy OR is this something that I should consider?
Thanks
Grant
Thanks
Grant
