Hey all, was wondering if I could get some help/advice on this Jeep I just got for my job as a postal worker. It is of course RHD. The thing has been decently kept up. Oil changes every 3-5k and all that. Motor has nearly 300k miles on it, transmission replaced with a jasper reman. Heater core was toast so I went ahead and bypassed it while I wait to work up the courage to tear the dash apart and fix it the right way. The main issues I'm having with it are the following
1. every o2 sensor is throwing a code
2. random/various misfire code
3. rough idle
4. oil pressure dropping to the point of the dash light going off when idle after driving for about 20 minutes
I think all of those are PCM-related but could use some confirmation on that
5. the main reason I'm here right now is that I was planning on cleaning the throttle body, and when I went to remove the air hose connecting it up, the wire connecting the IAT sensor to the manifold snapped, or at least I think it did? Regardless I now have a pigtail just kinda... there. Hanging off the air hose, just chilling.
I've got about a month still before I have to actually use the jeep for my work and want to get it in tip-top shape before then, but I'm having a hard time figuring out where exactly that wire is supposed to connect to. I removed out all the old rotted manifold insulation to see if I could find a wire trace down there but I haven't had any luck so far.
Any help appreciated.
Thanks!
3. rough idle
Thanks!
