What LED bulb did you use?That's what I use. I installed an LED bulb in it and it's super bright.
Finally got around to installing my Noico sound deadener in the LJ. Haven't been at highway speeds yet but so far the difference is amazing at 0-30 mph!!
View attachment 157763View attachment 157764View attachment 157765
The LED light i used was a cheap day time light kit that I bought off Amazon i believe. I bought a handful of them as they were so cheap. I Iiked the possibilities these thin yet bright lights offered. At less then 3/16 thick, you can mount them just about anywhere.Like that a lot. Can you tell us which one it is?
I was thinking of doing some type mod that will make use of an LED strip running off the wiring that is already therei unplugged mine when i got my TJ. ive never plugged it back in. But i dont know what else you have going on with your electric situation.
GoodLuck!
You can but you need to a manual or LED switch...or hot wire the crappy OEM one.I was thinking of doing some type mod that will make use of an LED strip running off the wiring that is already there
Exactly what I'm envisioning of doing. Did you run off the stock wiring location/cabling?Installed a LED hood light. Gonna be handy I'm sure. View attachment 157520View attachment 157521
How did you get the arb switches in that space?
There is a thread here somewhere w/ an Ebay link that I couldn't find either that has a mercury type switch.Exactly what I'm envisioning of doing. Did you run off the stock wiring location/cabling?
