robert_tj_ski
Wall, I've been cleaning the frame for past few days now... it all looked good till I got to rear end... hole about 1"wide... afraid it will get much bigger if I'll keep scraping it.... desicions desicions..... ugh
Mine is a Summer Jeep so the heaters wouldn't be needed. But what did that cost you if you don't mind me asking? I know upholstery is not cheap.. Was it cheaper for you to go that route versus. seat covers?
If I were you I’d see how much rust I could rip off that hole with your finger. It’ll tell you how compromised that area of the frame is. Better to find out how soon you need safety caps. Also better to find out in your driveway than on the highwayWall, I've been cleaning the frame for past few days now... it all looked good till I got to rear end... hole about 1"wide... afraid it will get much bigger if I'll keep scraping it.... desicions desicions..... ugh
Before you admit defeat, check your valve cover gasket. I fixed my RMS leak by replacing the VC gasket.
It depends on which source you look at for the '05/'06. Long story short: I came to the conclusion that most of the sources are flat wrong, and that the '05/'06 takes the same back elbow as the rest. Why? Because mine was idling at 1200 RPM, taking 2 or 3 seconds to come down to even that from 1800 or faster. I had to special order the elbow from Rock Auto because everybody local only had the front/through elbow. Now the engine idles and revs correctly and isn't sucking an incredible amount of air through the crankcase.. Mechanic at the used car place I bought it from went down this primrose path with the results I observed.Before I order the wrong parts, does anyone know the part numbers for the two valves on the top of the valve cover (PCV and CCV I think?) for a 2006 Wrangler? I did a search and I've seen that the back one has a small hole in the valve but then I read that 06 is different and doesn't have a small hole, it's similar to the front.
Because sometimes the 4:1 TC and manual transmission is just a pain in the ass. BTW, it's the same parts that Teraflex uses in their $40 kit for under $20.
Do you have part numbers?
I like it, awesome colour. How much was it ? (or did it come free with a Gypsy fortune teller ) hehe
Did a bit more painting on the Jeep - and confirmed that the oil pan gasket will definitely need to be replaced. In the meantime, I just won't park it nose down. I was already planning on replacing the rotten spare tire and rusty spare wheel - in fact, a matching OEM wheel is slated for delivery Thursday - I'll need to pick up a used tire similar to the street tires already on the Jeep to tide me over "for now" until I'm ready for bigger tires and the 2" lift.
Anywho - good thing I had the wheel on order with plans to off the rotten tire, because I went out this afternoon to lock the Jeep up, and found this:
Not really surprising, it must have made a nice pop when it let go, but I didn't hear it! The tire had about 23 lbs air in it when I first inspected it, Goddess alone knows how long it had been since it had had the full 40PSI in it, but I aired it up and it held, to my mild surprise - till now! Now I gotta figure out how to get rid of this thing! I'll see if the garbage here will pick it up on Thursday - they'll take just about anything.
