jmd349
I dig that shift knob. Can you share the source?
Here you go: https://www.quadratec.com/products/12600_01XX_PG.htm
Thanks
ThanksHallo Fonz5
.are you looking for this shift button?
https://www.4-wheel-parts.de/en/Bil...ransmission-Drake-Wrangler-TJ-year-97-06.html
Welcome to the best forum for tj owners. Make sure you post some pics. We like pics.Finished bed lining the interior, installed some rocks lights and threw some new tires on. Sent it off for some fresh paint and some body work today
Red with Spice is such a great combination on Wranglers. I love it.Installed a new Bestop Spice Sailcloth Replace a Top with tinted windows.
The original top was more like dark tan and was trashed. The spice looks great and still looks good with the camel interior.Red with Spice is such a great combination on Wranglers. I love it.
I need to do the same thing...Finally cleaned the factory clear sill protectors off. What a job. Before and after.
View attachment 151149View attachment 151150
A lot of patience, more than a few hours to dedicate to it, and a handful of plastic razor blades. Goo Gone to clean up the small stuff that the plastic razor blades will not cut loose. (Mainly glue/adhesive) the heat gun softened it up maybe a little, but you dont have to have one to get the job doneI need to do the same thing...
What/how did you go about getting yours off..???
https://wranglertjforum.com/threads/post-up-your-red-tjs-ljs-with-tan-camel-interiors.20064/The original top was more like dark tan and was trashed. The spice looks great and still looks good with the camel interior.
I’m confident that either the clear isnt that deep or there is no clear at all on the inside door sill; there is an area that the factory clear sill protector folds towards the inside of the tub about an inch wide. That area while painted, doesnt appear to have much clear protecting it. However, the part of the sill you can see can take a plastic razor blade on it all day.
I dont advocate intentionally try to dig it in.
I would also suggest adding a sill protector immediately after getting the clear one off. Something like a rugged ridge one. Something plastic and more robust, able to hide the scuffs and dirt.
