I feel a little out of touch with this thread since I started my build thread. Just popping in to say hello. RJ60 installed.
Well done.
No, that's from putting on new windows. That's the slop you get when the windows aren't made with the top I guess?Is your soft top normally that loose in the back? Or is that just from changing out the hinges?
...and his steering wheel is on the correct sideThat is one fine looking Jeep
I have used boltdepot.com to source unusual or odd bolts that regular stores don’t carry.Installed a 1.25" body lift, for no other reason than it gives better access to the frame for preservation work. Some of the rust pictures I've seen- holy moly.
If I can find a long enough 7/16 x 20 bolt I'll raise it another half.
So I cant see what was wrong with your old one hahahaReplaced the wiper motor. OEM motor had wiped its last. Managed to pull the rubber boot off and put it on the new motor without wrecking it. View attachment 150977View attachment 150978View attachment 150979
I dig that shift knob. Can you share the source?Replaced the stock stereo head unit with an aftermarket JVC head unit. This was incredibly easy, and I highly recommend forking out the $24 to have Crutchfield wire up the harness adapter. Just the new head unit alone has brought back some life in the stock speakers. I'll be looking to upgrade speakers next in a couple weeks.
Also, while I was at it I replaced the HVAC bulbs with new LED bulbs. A couple of the stock bulbs were shot, so this was a huge improvement. Went ahead and swapped out LED's in the foot-wells and sound bar also.
Before and after pics below.
