Hello, what make/model subwoofer did you install? Looks like it is powered, and fits well.
Rockville 400
BTW, Welcome, this is a great place.
Finished the SYE and put the transfer case from -2" back to normal height, and swapped the upper control arms/set rear pinion angle.
Took a quick trip around the block and holy hell, it's not even recognizable as the same vehicle it's so smooth! I dropped the tcase from -1 to -2 while I was getting the funds for the sye kit,and that made it way better but this is so smooth I had no idea it could get this good.
I can't believe the PO was driving it around the way it was and just accepting it
I bought a non flip and tumble base and cut it down 1.5” then welded on some 2” angle iron cut to match the profile of the floor on the inner side. I them drilled the top to accept the seat base slider and mounted the PRP adapters and seat.
There was a bracket floating about that lets you bolt a hideaway system sandwiched between the seat rails and the seat, thus moving the box away from the floor and allowing a passenger to put their feet under if possible.FINALLY got around to installing subwoofer and tweeters...So nice.
(I need to pound those seatback fasteners in)
Not sure what year your Jeep is but the 97-02 seats sit you up higher than the 03-06 seats by about an inchNice!! a welder is my purchase list. I'm not 6'5", but have a long torso and would love to sit at least an inch lower in the jeep.
DrippyCouldn't find toilet paper at the grocery stores. So I decided to tinker with the Jeep again. Installed a NOS GM under hood light to the tailgate glass. Tapped into the OEM dome light for power (PINK wire) and grounded on the tailgate.
What’s the secret to bring tools in the kitchen without getting “caught” ?Got a new floor jack. 3 ton. View attachment 148715
First time ever that a see a off-road JackWhat’s the secret to bring tools in the kitchen without getting “caught” ?
Same here ,I added seat lifts to my driver and passenger seat. What a difference it makes! So happy with this mod and would recommend it to anyone!
Easy. Spoil your spouse just as much as she spoils you. Atleast that’s the way it is in my house.What’s the secret to bring tools in the kitchen without getting “caught” ?
Its awesome. The rubber tires roll over all kinds of stuff. The bottom has a flat skid on it for the soft stuff like sand.First time ever that a see a off-road Jack
Neat storage too for the extension![]()
PERFECTION!!My current YJ build’s license plate came in and I’m confident that you will like it.
Come on. There is no way that can compare to the other speakers in a TJ/LJ.
It sounds different but not bad.Come on. There is no way that can compare to the other speakers in a TJ/LJ.
