Seats Good replacement seat
How much are you willing to spend?
Any requirments that you are looking to be met with an aftermarket solution? Ex. Heated seats, adj lumbar, leather, etc
Open to having the factory seats re-foamed and reupholstered?
Took seat to a upholstery guy today and he said seat was too rusty to get hardware and plastic knobs loose and xippers loose without tearing seat up. I have another seat was going to have that foam and cover swapped over. This is basically a hunting jeep but going to run around in it also. Tryjng to use what i hsve.
The 03-06 swap worked well for me. Firmer bolsters, higher position with risers, and bolted right in
IMO a salvage yard might be your best bet. DaveysJeep or Collins Bros will likely have what you need.
Call Gilbert jeeps in Athens,Al. They may have a set.
I fixed the foam on some with 3m spray contact adhesive and foam from a salvage yard , and put Bartact Seat Covers on , worked great , fast and didn't even pull the seats.
