I have searched and searched and found no one with my particular problem.
2004 Unlimited with 4.0L and auto transmission with no error codes.
So the problem is intermittent low idle at a complete stop. The idle jumps up and down about 100 rpms around the 400rpm range at a period of about 1 second. There are no troubles while driving and it starts the moment the wheels actually fully stop. Twice in the last 6 months it has actually cut off while coming to a sudden stop but started right back up with no issue. I have cleaned the throttle body, replaced/cleaned IAC, replaced TPS, checked for vacuum leaks, replaced spark plugs, fuel injector cleaner, higher octane/different gas, and replaced ignition coils assembly (it had gone bad). Here is the part that makes it odd compared to everything else I can find. While rough idle is occuring (and it occurs during cold and hot engine times) I can stop the low 400rpm idle by two methods: 1- lightly tapping the gas. Just enough to jump it 200 or so rpm and then the idles just fine until I drive and then come to a stop again. 2- shifting into neutral (or just out of drive) for even a short moment. I can then shift back to drive and it will idle fine.
I spoke with a couple of mechanics and they have both insisted it was in need of an IAC cleaning despite my insistence that I had taken it apart and cleaned it thoroughly and that it wasn't very dirty to begin with.
Any help with this would be greatly appreciated as I am out of ideas and can't find anyone with this exact problem (only similar problems).
