Goin' to get all touchy-feely with the shortbus while the wife and kids are gone.![]()
Polished the wheels for the first time in a very long time. Buddy helped.
Does anyone know where to find a similar wheel to these Eagle Alloys? They are 8 hole (decor, not bolt pattern obviously) and I think they would just be aluminum since they build up crap/pitting over time. They came on my 2004 Sport when I got in 2007. I'd like to get the spare time
and tire matching. The other 4 since they are new. The spare time is a stocker rim of some sort.
X2 on 2 chits about football.Tell you what I'll be doing Sunday. My wife is taking the kids to a friends house for a Superbowl party. I could give two chits about football so as much as I'd like to keep the kids busy and play in their pool, I'll be going over every ground and electrical connection front of firewall to try to trace down a possible O2 sensor gremlin. Goin' to get all touchy-feely with the shortbus while the wife and kids are gone.![]()
Gonna be a new holiday when you find this issue! It a mission nowTell you what I'll be doing Sunday. My wife is taking the kids to a friends house for a Superbowl party. I could give two chits about football so as much as I'd like to keep the kids busy and play in their pool, I'll be going over every ground and electrical connection front of firewall to try to trace down a possible O2 sensor gremlin. Goin' to get all touchy-feely with the shortbus while the wife and kids are gone.![]()
Automotivetouchup.comI tried to occupy the same space at the same time with a deer this morning. I got off lucky. Bent the front quarter panel a little, and put a small crease in the door.
Cost Analysis says it would cost too much to fix for what it would be worth, so I guess I'll just live with a few more blemishes.
Anyone know where I can get yellow touch up paint?
View attachment 137215View attachment 137213View attachment 137212
Your new LJ looks a little short.I started taking parts of my late beloved 2000 tj to start making a pile of upgrades for my maybe new 2001 tj that I test drove and took to the mechanic for a new car inspection. I sure wish I had a rack to put things up on it was so nice to walk around under it looking at all the things.
Little sisters break all your best toysBut both her and the tree are going to be ok
Potential replacement rig
Need a lift upgrade like this for my garage
It has a lot of little things like burned out bulbs, wiper sprayers don't work, visor is missing, nothing that is too big and all the things I can get off my donor jeep. The more real issues are a oil pan gasket, the lifter tick that all of mine so far have had at one point, and then the next picture is one I have a question on. This is the transfer case and I would have expected it to be translucent but it is like pepto bismal you can't see through it at all. The rig looks like it was never taken off road and the guy selling it sais he and the prior owner used it for a fun run around no offroading. they both toed it with their motor home.
Question. Is peptobismal expected color situation for the transfer case (ashamed I hae never changed one I always have a shop do the oils) View attachment 137780Is this an issue for concern? what is the remediation. drain fill repeat until it is translucent like atf?
Thanks
Thanks I hadn't been in to a jeep transfer case but all the times I have had milky fluids it was water and no good. I will put that top on the list to take care of if I get it.Your new LJ looks a little short.
It looks like the transfer case got water in it. It could be the seals or water getting in through the vent hose. I would pull the back of the TC and give it a good inspection. If all is good clean it and refill it with new fluid.
If the rest of the Jeep is in good condition and the price is right I wouldn't make it a deal breaker. A np231 can be had pretty cheap. Most likely it will be fine with fresh fuids, though. It might be a good negotiating point if its from a dealer.Thanks I hadn't been in to a jeep transfer case but all the times I have had milky fluids it was water and no good. I will put that top on the list to take care of if I get it.
Does anyone know where to find a similar rim to these? It's an Eagle Alloys 15" rim with 8 decorative holes on the standard lug pattern. Idk the actual finish, but they build up gunk over time. They don't have a finish. I'd like to get a 5th matching rim and tire for the spare since the tires are new. @Davidtj @k-huevo
Thanks guys that was my hope. The rest of the jeep seems good other than I think some minor things but I do plan to go talk to him tomorrow and lay out my concerns on the oil pan, front dif, transfer case, (all repairable but should be reflected in the price) and ask what his bottom dollar is because I would like to buy it, and he would like to unload it and so we should work some thing out that is good for us both.If the rest of the Jeep is in good condition and the price is right I wouldn't make it a deal breaker. A np231 can be had pretty cheap. Most likely it will be fine with fresh fuids, though. It might be a good negotiating point if its from a dealer.
Just saying it's a 15" Eagle alloy wheel isn't really enough information...Does anyone know where to find a similar rim to these? It's an Eagle Alloys 15" rim with 8 decorative holes on the standard lug pattern. Idk the actual finish, but they build up gunk over time. They don't have a finish. I'd like to get a 5th matching rim and tire for the spare since the tires are new. @Davidtj @k-huevo
| Part Number | Finish | Diameter | Width | Bolt | Offset |
| 0589-5812 | Polished | 15 | 8 | 5x114.3 | -30 |
| 0589-5712 | Polished | 15 | 7 | 5x114.3 | 2 |
I have one of those in 3.25 BS, and I couldn't find a single replacement. This model is similar https://www.amazon.com/dp/B004J356BW/?tag=wranglerorg-20Does anyone know where to find a similar rim to these? It's an Eagle Alloys 15" rim with 8 decorative holes on the standard lug pattern. Idk the actual finish, but they build up gunk over time. They don't have a finish. I'd like to get a 5th matching rim and tire for the spare since the tires are new. @Davidtj @k-huevo
