Tldelaney
Disassembled my highlight jack for the LJ. Stripped most of the parts and powder coated it to match with the colors Blackjack and Beige metallic.
Let me know how it does. Mine is hard to start but mainly in the cold weather. So ever since winter started, I have had to basically crank for a second, then let off, then crank again and then it starts.
What do you have to do to get it out?View attachment 133528View attachment 133529View attachment 133528
If you’ve never cleaned your fan you should! Made a world of difference! Takes about 5 minutes to remove.
Leaves and twigs can accumulate in the fan from getting through the grate on your windshield cowling. You hear the sound of something spinning around in there for the first time, and you’re praying to the Jeep gods to have mercy on youWhat do you have to do to get it out?
I heard some noise in there when I first got my Jeep but it stopped but now after seeing Mike JF’s post I would like to clean mine but need to know what to remove to get to it.Leaves and twigs can accumulate in the fan from getting through the grate on your windshield cowling. You hear the sound of something spinning around in there for the first time, and you’re praying to the Jeep gods to have mercy on you![]()
On my 2006 it inside under the dash! Just unplug and pull down the one tab that’s located just toward the firewall from the plug. Twist it while pulling down on the tab. If you know how it just a couple minutes to do. There is a video on YouTube somewhere if you search.What do you have to do to get it out?
But he has a 98My 2006 is inside under he dash.
If you look at his profile @TDB55 has a 98 Sahara.My 2006 is inside under he dash.
Right!! That would make too much sense wouldn't it...Now why can't they make the heater core changeable like that? LOL
