It’s a GenRight complete cageWhich sport cage kit and floor tie in did you go with?
https://genright.com/products/jeep-tj-laser-notched-full-roll-cage-kit.html
I bought that switch with the intention of putting it in before I found out my lights timed out. So if anyone needs one, selling cheap.
Ah you went with the weld in kit, I have thought about going that route. My 2 problems with going that route are, lack of a capable welder and seriously rust welding skills!!!It’s a GenRight complete cage
I used a hammer and a drift on the backside of the harmonic balancer close to the shaft turning it a bit every few wacks. Starts slow but it will come off.Pulled the transfer case out. Need to buy the 3 bolts needed to remove the harmonic balancer thing and a 1 1/8” socket to remove the nut from front drive shaft yoke.
In the meantime, touched up some rock rash on the rims with touch up paint on all four wheels.
Bought it through Quadratec. Paid 35 plus tax. Sell for 15Who's switch kit..??
What is cheap..??
I'm interested..
Gotta keep those skills sharp friend.Ah you went with the weld in kit, I have thought about going that route. My 2 problems with going that route are, lack of a capable welder and seriously rust welding skills!!!![]()
I have a 110 mig in the shop but I don't think it quite fits the bill when it comes to welding roll bars together.Gotta keep those skills sharp friend.
Pardon my ignorance but what’s a drift?I used a hammer and a drift on the backside of the harmonic balancer close to the shaft turning it a bit every few wacks. Starts slow but it will come off.
I had the same issue, so I bought a section of metal gutter cover, cut out a piece and hot glued it to the under/back side. Not only were the fragile vent sections broken but the thin solid part in the middle of the vent area was also broke.
I think it looks good and seems to work very well.
View attachment 123264View attachment 123265View attachment 123266
Uh why?Going backwards in life. Began disassembling my '99. Started with removing the bumper and winch combination. The front Dana 44 was also removed and replaced with a Dana 30.
I guess that word kind of showed my age.Pardon my ignorance but what’s a drift?
Edit: I googled it and I see it’s a punch which I do have. I’ll give it a try. Thanks!
Uh why?
Was it 1-1/8"? Shoot, i was just a hair off..Pulled the transfer case out. Need to buy the 3 bolts needed to remove the harmonic balancer thing and a 1 1/8” socket to remove the nut from front drive shaft yoke.
It's being sold.
Yea 1 1/8”. But I had a slightly larger metric impact socket that worked fine.Was it 1-1/8"? Shoot, i was just a hair off..
