Windshield hinge bolts won't come loose
I plan to replace my windshield this summer and I'm not looking forward to "the bolts". My plan is to pick the paint out of the bolts, heat them up to loosen the Loctite, insert a Torx bit and give it a good whacks and then use my impact driver. As with a lot of stuck bolts, if you try to tighten them first they will often loosen off more easily. It doesn't take much, usually just enough to break the rust seal. After that, reverse it a bit with your impact driver then tighten it, reverse it more and tighten it again to clean up the threads as you go. Unless they free up totally it's best, I think, to switch to a ratchet to get a better feel for the bolt. Impact drivers don't always give you that.
SGTJ - Did you buy a repro windshield and if so are you happy with it? I bought a pair of "foreign made" fenders for my LJ and was very satisfied with how they fit.
Reactions: SGTJ
May have luck with this tool...
Reactions: KCsTJ and SGTJ
I’m putting a whole new frame in so maybe I’ll just completely drill them out...damaging the old frame and get new hinges.
I heated them again today. Nothing. Broke an easy out into one of them. And the impact driver still didn’t budge them. So because I am replacing the entire windshield frame any way I just drilled them completely out. Many thanks to everyone’s suggestions. I will be trying those when I attempt to replace the hinges and the tailgate.
Some picture of how badly rusted the Torx heads were and the awful state of my old frame and windshield.
81331
81331
I bought a brand new windshield and I am happy with it. It came primed and I took it to a local paint shop. I think it came out looking great. I put the glass in last week.
Reactions: PCO6
I couldn’t get mine to move with the hand held impact driver. I think it was probably operator error and massive amounts of rust. Yours look great!
Reactions: azroc909
That's good to know. (y) Thanks
I should have said windshield frame...I also have a new tailgate that needs to be painted and I am going to get new front fenders. Mine are all rusted. The glass I bought through a place online called Jeep Glass.
Reactions: KCsTJ
This may sounds silly but I had the same issue and rather than screw up the paint by using a torch I took a high heat soldering iron and held it in the torx bolt recessed area for about 5 minutes. It melted the locking agent and the spun the bolt out easily after it was good and hot.
Reactions: Tray Burge and SGTJ
I’ve heard people have had good luck with the soldering iron. I’ll have to pick one up for when I do the tailgate. I wasn’t too worried about the paint because I am going to replace the inges anyway. The torch didn’t harm the paint as far as I can see.
That's exactly what I was thinking about doing! Glad to see it works.
Currently fighting the same thing, they started to give so i stopped to consult the internet. What king of heat are we talking about here if not a propane torch? I already have one of the impact driver doo-dads and can try swinging a hammer at that. I really don't want to mess up my paint or anything trying to do this.
also posting here because i didn't think i needed to start a whole new thread.
Even here in Oregon (with no rust) mine were a pain in the ass to get out.
One of them I actually had to get out with a screw extractor. I replaced them with stainless steel bolts and used plenty of anti-seize.
Reactions: reddvltj
