Is this Wrangler a TJ or a YJ?
So all the smarts can flow out of our ______.
But I find it interesting that on the T/C, there appears to be some kind of lever. Like maybe a PTO?
And is that the ft. dr. shaft or a PTO shaft for a winch?
A sickle bar mower on a TJ? That would be exciting to have!
HUH:unsure::unsure::unsure:??? I see a front drive shaft attached via a double cardan joint to a drivers side drop t-case and a rear rive shaft with a slip yoke, disconnected from the rear output shaft.
Not quite sure what lever your referring to.. I do see what looks to be the shift lever directly behind the front yoke where it meets the case??? Interesting:unsure::unsure::unsure:
I don't really know what a 231 looks like because I've got an Atlas.
View attachment 111700View attachment 111700
Reactions: reddvltj
Had me bewildered for a second I saw that you quoted my post but I didn't see any reply.... then I looked in the body of the quote. Yeah I can see how that might look just a little different lol... Not sure if there will be an Atlas in my future or not. I guess it all depends on when and if a V-8 swap ever becomes an option.
"HUH:unsure::unsure::unsure:??? I see a front drive shaft attached via a double cardan joint to a drivers side drop t-case and a rear rive shaft with a slip yoke, disconnected from the rear output shaft.
View attachment 111700View attachment 111700"
