Can Currie 4” be used with 3” lift shocks and springs?
Mml will reduce the driveline angles. Also, when paired with a body lift it makes it so you don't need to modify the fan shroud.
Reactions: Grey_Machine7.3
The body lift makes a bit of room for tires similar to chopping the body. The motor mount lift often starts as a way to soften the rear driveshaft angle after a lift. Once you get into raising the transfer case skid, the MML is part of stuffing the entire drivetrain higher into the body.
mine's a 3" with 32's
Ooohhh.
Yeah, my wife is going to hate the Wrangler more than my 4runner bahaha. But it is still sitting in my backyard all ripped apart. Hehe a slow rebuild process
