I would love a real high line but I know they are really rare so it'll depend on when I get to this step
They're not rare at all. They're rarely done well, but that's different.
An AEV highline is pretty rare. You can get Highline fenders from any number of vendors (Poison Spyder, GenRight, JCR come immediately to mind). Then you have to cut your hood, or take your chances with a DuroFlex. Personally, I'm going to try it it DIY.I would love a real high line but I know they are really rare so it'll depend on when I get to this step
Yes...this. I've found a LOT of examples of hacked up DIY highlines. I've seen it done well a couple of times (outside of a kit)They're not rare at all. They're rarely done well, but that's different.
Step one, find a rusted out fender to screw around with (shouldn't be too hard, living where I do)
Step two, Hack it up and figure out how to make it all work (all the stuff that is on the fender needs to be relocated or re-attached somehow).
I will probably pie cut the fender so I can re-establish that curve around the radiator shell/grill. The other big issue is getting the wedge right by the rear mount. The fender bolts to the tub in a few different spots. The straight line along the outside is easy. The ABS and battery trays are what will be a challenge to make work. However, those spots are where you loose tire clearance when you turn, and incidentally, why the Metal Cloak fenders doesn't really give you as much clearance as they say they do.
Doing the hood is relatively simple. You measure out a strip equal to the amount you raised the fenders, cut the flange off the bottom, cut your strip and weld back together.
It's very expensive as well, IIRC.GenRight has a nice kit, but it's a bit of work to install.
I've been doing some real digging on DIY Highlines and there is so much that can go wrong. But when it is done right... That's exactly the look I want. If I can't find the AEV highline kit I might have to go DIY because I really don't like the look of any of the other fender options.
The DIY highline sounded interesting to me for a while. But even in the better done versions, I've never liked how the area around the head lights look. Aesthetically, AEV got it as right as it can be. Even then, it looks off to me.
Exactly. Personally, I am just not a fan of the look.The DIY highline sounded interesting to me for a while. But even in the better done versions, I've never liked how the area around the head lights look. Aesthetically, AEV got it as right as it can be. Even then, it looks off to me.
Not for me to say. Everyone likes what they like.Would you say it looks weirder than the other highline looks? Is it possible to get 35"s without the highline by making sure I have the right bump stops? I don't want to lose the up and down travel by restricting myself.
It's all about compromise. You can fit 35's with as little lift as necessary to keep the tires out of the fenders at ride height. But...up travel is going to suffer. Don't want to highline and retain a decent amount of up travel? Plan on somewhere around 5" of lift. Anything in between will "work" depending on your definition of "working.".Would you say it looks weirder than the other highline looks? Is it possible to get 35"s without the highline by making sure I have the right bump stops and keeping the stock fenders? I don't want to lose the up and down travel by restricting myself with
Yup. That's why the metalcloaks don't get you as much as advertised. Its also why I'm getting a scrapped set of factory fenders. I want to see where the interference really is, then devise a way to make more clearance. No sense in raising them, if you're not giving the the tire room to turn.Just remember that if you really want an improvement, you need to move the wheelwell back in the areas that matter.
It's all about what you wanted the vehicle to accomplish and look like. I like the highline look, so I'm going to try it. If it looks like poo poo, I'll do something different. I'm going to try and replicate the AEV fenders. I'm not a fan of flat fenders.
I far prefer the AEV highline look over the flat. It keeps the Jeep shape and if I'm trying to stick closer to the stock look I feel like the AEV style is a must
Same here, pics didn't bother me and I thought the look was cool. Saw a few in person and just not a fan.Preference is preference; whatever you like is cool. I used to be a big fan of the AEV look, but as time passed my appreciation faded; to my eye, there are a few areas that don't look right...but that's just me. My only real objection to a stock-ish fender is that it's a visual impairment compared to a tube...but that may not even matter for your uses.
