Drove it to a site for a raptor survey this morning. 27 degrees heading up into the mountains with snow (I thought spring was here, apparently not). The seat heaters worked well
Don’t get rear ended!![]()
Bababooey - Do you still have the Nth Degree manual TT? If so I'm interested.
Awesome photoDrove it to a site for a raptor survey this morning. 27 degrees heading up into the mountains with snow (I thought spring was here, apparently not). The seat heaters worked well
Awesome photo
I relocated the 3rd brake light wiring yesterday in order to make better use of the tailgate. Had to wire it up twice though because for some reason black on the tub connects to white on the tailgate???
Drilling holes in the tub sure does come easy after a while![]()
No kidding. I'm past the point of being able to count all the ones I've drilled with *edit TWO HANDS. It may still feel a bit odd when we cut the tower off the front shock mount tho.The first hole is the toughest.
They should plug into the stock harness. Anti flicker harness is only needed on JKs.Do I need an adapter, and anyone have any part number?
Looks like your Jeep has served toad duty.
I'm pretty sure it was a Camper tow. The dealer told me the day I picked it up that the guy bought a new JL Rubicon.Looks like your Jeep has served toad duty.
