I discovered I might have a timing issue yesterday when the jeep popped P0016, P0340, and P0344.
Swapped in the cam sensor that came with the Crown OPDA and it fired no issue. Started fine this morning and the CEL is gone.
Time will tell.
Spent the rest of yesterday getting most of my OR FAB tire carrier on.
Today I'll finish it up. Basically just hanging/adjusting the gate.
Snapped the retainer clip for the hose going into the air canister in the passenger quarter panel.
Anyone know where to source one of these?
82943
Those are EAG pocket style flares. Install was easy. For the most part it uses factory holes. Though Some did not line up on the front flares. $170 on Amazon and shipping was fast. I ordered them late Friday and received them by Tuesday.
Reactions: Cole
I repaired the marker light wiring: cut the wires offset, dipped the wires in flux, tinned the wires with SN63/PB37 solder, slid on 2 different size heat shrinks, one large, one small, soldered the wires together, cleaned the flux off with isopropyl alcohol, then slid up the small heat shrink, shrunk it, then shrunk the larger one, wrapped with 3m tape. Installed a bulb to test, works as advertised.
Reactions: B4_685
Time will tell.
junk yard, look at the chrysler mini vans and cars of the same ear as your jeep.
Reactions: BTango
Installed LED headlights, painted the headlight bezels black and removed the milk jugs.
View attachment 82948View attachment 82949
When I painted the bezels I also painted the ring that retains the headlight. Scuffed up the plastic chrome on bezel with scotch write but it sill came off a little when I used a torx screwdriver to adjust the beam.
83013
When I painted the bezels I also painted the ring that retains the headlight. Scuffed up the plastic chrome on bezel with scotch write but it sill came off a little when I used a torx screwdriver to adjust the beam.View attachment 83013
On my to do list! I have the black headlight bezels, but now that chrome ring sticks out like a sore thumb with the black bezels. Looks great!
