80581
Reactions: KCsTJ
Ok, so I got some ospho and sprayed down the new to me dana 30 that I am sticking into my LJ, I also got some pics of the rear springs I am looking at installing, they either are from an JL or a JK, I dont remember but they have a definate bee hive shape to them.
Reactions: BeavisTJ and TJMIKE
Hey I do the same thing, except I use google gsheets. I have way too many vehicles and toys to keep track of it in my head.
Yep! I have a google sheet for tracking expenses and graphing the mileage but I guess I have an affectation for a paper log books in the glove box. Leftovers from the military, I suppose.
Reactions: RussTJ, ac_ and JMT
Replaced the stock track bar bolt (axle side) with a larger grade 8 bolt- 7/16"-20, 3" long yellow passivated bolt from ACE. I ground the old nut off its retaining tab, then ground the tab opening to capture the new grade 8 nut. Inserted the tab onto the nut using an socket larger than the nut (light interference fit). Drilled out the curry track bar bushing to 7/16". Installed bolt and nut and Torqued to 60 ft-lbs. Worked like a charm and certainly seems a lot beefier than the stock bolt- it should hold preload much better, thereby preventing the bolt hole enlargement issues which can cause wobble.
The stock bolt seems a bit undersized for the job, considering how much lateral load it has to resist...
Thanks @mrblaine !!
Reactions: TJ Starting
Thanks Mr. Blaine.
FYI, if you put an @ symbol before mrblaine, he'll see your post! Otherwise, probably not likely....
Great work on your rig. I love the Currie setup, wish I had one, but I'm happy with my ZJ conversion...
Reactions: ac_ and Beach_vibes
Got it registered and did something just for fun.
I was thinking about getting a set of those. They would match my tire cover. LOL
I bought my Jeep from a used car lot on Jan 5th. I am still waiting for the registration tags and pink slip. I'm going to wait till Friday, then give the DMV or the car lot or both, a call.
I got mine on eBay for $15.50, shipped on a slow boat from China (use the Make Offer feature).
The screws it came with were too small and too short but I found some #8x1-1/2 exterior screws that worked well.
https://rover.ebay.com/rover/1/711-...0001&campid=5337789113&icep_item=264128399083
I bought my Jeep from a private seller on Feb 5th. Yesterday was my last day to transfer the title before incurring a penalty. Lol.
Reactions: KimsJeep
I got my turn signal and marker light guards. Painted them and then it started raining. LOL Depending on weather, I will try to install them tomorrow. I'll get the turn signal ones on for sure. The side markers I need to drill holes so I may wait for a warmer day for that. Don't want to do to much in the cold. :D
Fingers crossed my Brown Dog engine brackets and mounts will finally show up tomorrow so I sprayed down the bolts on the engine brackets and motor mounts with Kroil today to help loosen those puppies up.
I also got the transmission bolts out and while under there poked my finger up in the frame and found my cruise control vacuum canister was flopping around loose. I ended up taking the battery and tray out to get in and bolt it back on. While I was under the hood I replaced the air filter.
Man I'm enjoying working on this so far!
Hey i know this an old post but how was changing the brackets i am in the situation and i am trying to get feedback before i make my purchase. hope you can help. thanks!!
