They are 1.25" wheel adapters, not wheel spacers. They are the JK Moab wheels which are 17", not the 16" TJ Moab. The TJ Moab will clear the Super 16" kit without a spacer since that it what I designed it for. To be the largest brake kit that would fit inside a 16" Moab rim.
As were on this topic and I’m also going with JK Moab’s. With a SA would I need larger adapters to avoid rub? Does the mid arm provide any more clearance there? I was thinking of going 1.5” just to be sure, I’m going to be getting the same tires.
I think Obi said the backspacing was like 5.2 on them but I’ve seen other sources say it’s 6-6.25
Also, I’m guessing no issues with the Super 16 and JK moabs? That’s next on my order list
Lastly (and slightly off topic) what powdercoat color code/manufacturer do you use? I love the sort of semi gloss appearance to it and I read Obi saying it’s good and durable.
I was just thinking last night. That @ObiWanWebWheelr build has got to be my favorite build I've ever seen. I would have to credit that as my inspiration for my build. Every single thing on that thing looks exactly like the way I would have wanted it myself. Absolutely perfect!
I’ve sent you pictures of that LJ a lot, near enough exactly what my LJ is going to be
