Anyone know what these wiring harness plugs near steering column go to?
atlantatjowner
Atlanta
Anyone know what these 2 plugs could be coming off the main bunch of wires near the steering column? Rear Defrost , cruise or rear wiper maybe?
black plug looks like the SKIM (Sentry Key Immobilizer Module) plug but not yet sure of the white plug
How did you make out in identifying those two plugs? I have the same scenario after taking apart dash to change heater core. I don't remember unplugging those two.
Not to steal your post but I installed a hardtop on my 05 TJ with the OEM wiring harness from the same year Jeep and I cannot find the plug to work my rear window deicer. It's a larger black wire with a white stripe and the donor vehicle has since been scrapped. I really don't know where I should plug this wire. Any ideas out there would really be appreciated!
Did you know what the white plug is for? I would like to know too.if the plug is used for courtesy lights, could you please tell me the number indicated on the lamp holder? Many thxs in advance
on the back of your gang pannel , (the one with all the colored connectors under driver side dash ) i think it’s blue or yellow male connector that plugs in but you should have the same black with white stripe wire on female side and your male connector will have an empty slot with no wire , youl have to connect it and run a wire back to the ass end of ur jeep
