Run almost the same tires at 255/75r17 and their great for a “mild build” sort of speak right
I was considering that tire until I found my MOAB rims. I really wanted this wheel so I went with 265 duratracs. Very happy with them.
Reactions: Nicholas
I removed the softtop, stored everything and then put the hardtop back on with a couple friends. Took like 5min with 3 people. The Jeep looks so different. I think I prefer the soft top look but it rains so much here in the winter. I think this will become a yearly ritual for me.
I also took the rear seat out. I had bought these tie down things that I installed along with fresh thumbscrews for securing the hardtop. Need to figure out a good compartmentalized storage for the rear.
I went for a drive later on and I'm sure it's in my head, but I thought the Jeep was a bit sluggish with the extra weight lol.
I also followed the instructions in the SKIM retrofit thread and got everything ready before I take the Jeep to the dealership on Tuesday. I'm removing the crappy Auto-mate aftermarket alarm system that the PO had installed tomorrow. The SKIM is a much better and elegant solution.
@Chris @glwood @jjvw this is my how TJ stands today. Thanks for all your advice early on. Can't wait for the regear to 4.88 next week. I've decided to stick with these metric 32 (31.6" to be exact, 265/75R16) duratracs.
Next immediate upgrade will be headliners for the hard top. Should I go charcoal or black?
That looks strikingly similar to my old black TJ Rubicon! Well done!
Your Jeep was a definite inspiration.
I can't believe how much different TJs look with hard top vs soft top. This is the same Jeep in both photosh. I'veI really fallen for the soft top. Wish I could run it all year!
View attachment 56563 View attachment 56564
See, I'm the opposite... I dislike the look (and noise) of the soft top. I run the hard top or no top at all. Sold my soft top years ago!
Reactions: Shane Mckinley
It's all relative. My other car (1999 Mazda Protege) has waaay more cabin noise than even the soft top. After driving that for years, I simply do not mind the soft top at all. I really enjoyed using it this spring and summer. I need to replace those damn straps connecting the bows before I put it back next year.
I contemplated not changing tops but then I remembered how much rain we get haha. I like the ritual as well, sort of like how I bring out my favorite sweatshirt for fall/winter. Plus this way, when I put the soft top back on, it'll feel even sweeter.
When do you typically put your top back on, @Chris? Do you drive your TJ a lot in the winter or use your Subaru for the most part?
I can't believe how much different TJs look with hard top vs soft top. This is the same Jeep in both photos. I've really fallen for the soft top. Wish I could run it all year!
Just think how happy you'll be to take off the hard top in the spring, and run that soft top again. I've been doing that twice yearly top swap ritual for years, and I love it. Hard top in the winter, soft top in spring, summer, and fall. I look forward to both swaps each year. It makes me appreciate both types of top.
I too like the look of the soft top more, but the hard top is also classy looking. Plus quieter, and more secure. I only lock my TJ when I have the hard top on.
What's your suspension setup?
2.5" lift with Fabtech springs, Bilstein 5100 shocks, Savvy Johnny Joint control arms.
Not the best of pics and not sure if they show anything useful. I took them the other day for posting in the thread with discussion on the adjustable front track bar but forgot to post there. Let me know if you want to see anything more specific.
In the Summer I take the top and doors off and never drive it without the top unless there is a 0% chance of rain. In the Fall I put the top and doors back on (the hard top I mean) and leave it that way until usual mid-Spring.
I don't drive it as much in the Winter though to be honest, just because we usually end up driving our other car. In a way, the TJ has become somewhat of a sunny weather vehicle!
Gotcha. Mine won't be a daily driver but I definitely plan to use it this winter (hoping to do a trip to Crater Lake for sure, never seen it in wintertime other than photos). That's why I started the other thread on winter prep to see what other folks do.
Do you do do anything specific since your Jeep will be sitting for a while unused? e.g., put battery on a trickle charger etc? I'm guessing you have a heated garage. I've never really had two cars before, so not sure what's the best protocol if you don't use one car much during winter, even something like ours where we don't get much snow but it still gets down to the 20s at times.
No heated garage, though it is always garaged. I have a trickle charger I keep the battery on, but other than that I don’t do anything other than go start it up every week and let it run for 10 minutes and get up to operating temp. I’ve done that forever and never had an issue. If I were going to let it sit longer than 3 months and never start it at all, then I might do other things, but that never happens.
Keeping it garaged is already a big benefit alone!
Reactions: psrivats
Re tightened both track bar bolts as much as I could tried avoiding tightening the front too much but that castle nut pin is a b*.
You should go back in with a torque wrench and tighten them to factory or manufacturer specifications. Having them tightened "as much as you could" can lead to wallowing of the holes and death wobble. :)
Reactions: Nicholas
Not today, but Friday afternoon I changed my oil. Shell Rotella 10W-30 with a Mopar MO-090 filter. Vs my wifes Jetta, the jeep takes roughly 30 min to change and thats because I let it drain for while. I changed the oil on her Jetta two weeks ago and it took me damn near 3 hours. 15 bolts to remove a skid plate, then the dealership had hulk tighten the old filter on, have to jack it up in order to get a drain pan under there...ugh.
I fixed an annoying squeak that was coming from the back of the Jeep every time the rear wheels hit a bump. It was just loud enough to notice, but not loud enough to be the first thing on my to do list.
I figured it was some part of the hard top, maybe the rear window frame, but I was wrong.
A couple weeks ago I swapped out my old, cracked body mounts for new rubber. But when I got to the top halves of the mounts next to the rear shocks, I couldn't get them out right away because I didn't have the tub lifted high enough. The wood blocks I was using between jack and tub would only fit near the front. I needed to move the jack to the rear of the tub, but had to find something else to stack on it and I was short on time. So I left those two old top mounts in place and bolted everything back up.
Yesterday, I finally got around to getting those last two body mount halves. With the jack at the back of the tub, I easily got the extra 1/4" I needed to pull out the old mounts and drop in the new rubber.
And when I drove the Jeep out of the garage, the squeak was gone!
Given the discussion we just had about NVH, I should have guessed it was that body mount.
Yep wife's benz is the same + 8.6 qts of mobil 1...
Hoping to replace my rear driveshaft ujoints today while in replacing the pinion seal and yoke, I’m worried about getting the new yoke in tight enough, I read that you can mess it up if it’s not in the same as the old., should I do the yoke with my basic tools or have a mechanic do the rear yoke?
Reactions: Nicholas
Re tightened both track bar bolts as much as I could tried avoiding tightening the front too much but that castle nut pin is a b*. When I was under I also noticed a lot of excess rear diff fluid coming out for the first time this much. Does anyone know if this would be a tough job to tackle that seal when changing the fluid next time ??oh and yeah Rositas so silly sometimes she like to pick me up. View attachment 56545IMG]https://uploads.tapatalk-cdn.com/20180924/6678bdac026445cf2f5fc9be01cad702.jpg[/IMG]View attachment 56546
Mine was doing the same thing , the rear ujoint is bad, and one of the ujoint retaining tabs on my yoke is missing..
Reactions: Nicholas
Today i found a way to remove a stubborn door from its hinges. I'm sure others have done this.
I removed the door hinge 13mm nuts and both doors were stuck.
I used some leftover 2 x stock as a platform for the bottom of the door.
I used Kroil and motor oil massaged into the hinge joints.
Alli had to do was swing the door back and forth 4 to 5 inches and the door worked itself loose within a couple minutes.
I used the Jeep's weight to act as a reverse press, easily removing the stuck hinge pins. :)
