Is that ur next purchase?
Could it be a 3 link rear with a track bar? There is a good reason to do that on both ends. The track bar, especially as seen on that axle raises the roll center of the vehicle and will reduce body roll through suspension geometry. A triangulated 4 link doesn't do that.It confuses me when people do custom suspension work and they build a 4 link with a track bar. You went through all that work why not do a triangulated 4 link and ditch the track bar.
I had to look it up since you mentioned it. Looks like the aam 11.5/11.8. Came along after my time, sure is a big sucker.Haha! No way. If I was going to do axles I'd probably do Currie RockJock 44s or 60s.
I don't even think you could fit that axle if you tried, it's massive. Wonder what it is... A Dana 100? :risas3:
What year Dodge Ram? My 1997 CTD has a D80 rear and Dana 60 front. I think the third gens started with the AAM axles. My buddy’s ‘06 has a 9.25 front and 11.5 rear. With the right lift, anything will fit. I’ll be putting those under my Jeep soon actually (when I get the money saved).
I got curious and found this on Google. Holy cow!
https://www.dieselworldmag.com/gm/u...1-5-aam-rear-end-for-your-gm-or-dodge-part-1/
@Chris I can see you dreaming about this![]()
Their Dream axles really. Are you going to update the progress on here?
There are several questions I have about the design choices they made.I wonder if the guy knows that upper sway bar links are failing.
