Currently in the process of a frame off rebuild of a 2000 TJ. Main goal of this project was to fix the rust by replacing the torque boxes and clean up/rust prevention on the frame. Since I am already deep into this, I plan on replacing all suspension components as well. While the project has been moving quickly, at this point I am overwhelmed with options. I believe there has already been a 2.5" suspension lift installed at some point because of the skyjacker shocks and what appears to be front spring spacers (correct me if I am wrong). My end goal of all of this is to be able to run 33" tires and have a capable off road build. I don't want to go crazy with the budget but I want everything I choose to be functional and last. I think where I need to start is with the lift kit and base everything else off of that.
Lift:
I initially wanted 3 - 3.5" but I am now leaning more towards a 2.5" with a 1" body lift. It seems like a more feasible lift size where you don't have to use a SYE and a t-case drop (I hate the way these look and you lose ground clearance. The whole point of a lift!!) With this being said, I find it impossible to decide on what brand I should choose, specifically what brand of shocks. Are their any preferred lift kits out there? The price of the Rough Country is tempting but all I hear is that they are junk. Replacement bump stops?
Do I need adjustable control arms and track bars? The bushings in the stock ones need replaced which I will do unless adjustable is needed and I should just fork over $$$ for them instead.
Is a pitman arm drop necessary?
My main question out of all of this is: Is their anything else I'm missing? Do I need to add or change anything in my plan to get more out of this? Should I place more attention to one thing or another? There are so many options and opinions on this topic that it all is so overwhelming. I have extensive mechanical knowledge but am new to the world of Jeeps. I know there is a lot of junk parts which is what I am trying to avoid. Thank you in advance for any advise or input on this.
Lift:
