What was your backlash? And for God's sake didn't use so much compound!
Mac, don't run a pattern unless your backlash is in spec. It will only make you chase your tail. Any time you change pinion depth you have to adjust the backlash.
Reading a pattern that doesn't have the backlash in spec is a waste of time!
Spec is .006 to .012 right?
Getting closer...moved carrier shims... passenger is .43 now and driver is .50. Than from passenger .40 and driver .60.
Backlash is .005. Pinion is .19.
More work to do tomorrow. Need heat in the shop.
View attachment 665239View attachment 665240
Definitely getting closerjust a touch deep now.
I know when were discussing some other axles...shaved 14 bolt I think...we were discussing how some folks preferred slightly deep.
Thoughts or just remove a thou from the pinion.
You're more than a thou deep. I would pull 3 and see.
Did that on an earlier pattern (didn't post pictures.)
View attachment 665284View attachment 665285
