Ok, time for lets argue about your favorite shocks
Front
Bolt Type: Flange Bolt
Bolt Size: M8x1.25x30
Bolt Position: Front Lower
OE Part Number: 6502 555
Quantity: 4
Nut Type: Lock Nut
Nut Size: M8x1.25
Nut Position: Front Lower
OE Part Number: 6101 695
Quantity: 4
Rear
Bolt Size: M12x1.75x65
Bolt Position: Rear Lower (these bolts have a long shoulder)
OE Part Number: 6502 473
Quantity: 2
Nut Type: Lock Nut
Nut Size: M12x1.75
Nut Position: Rear Lower
OE Part Number: 6502 835
Quantity: 2
Bolt Position: Rear Upper
OE Part Number: 3420 2467
Quantity: 4
coppied from @Chris thread
Reactions: Chris and Jmac00
Front
Quantity: 4
Nut Type: Lock Nut
Nut Size: M8x1.25
Quantity: 4
Rear
Quantity: 2
Nut Type: Lock Nut
Nut Size: M12x1.75
Quantity: 2
Quantity: 4
thank you, just wanted to make sure I get the right thing
Reactions: DougyintheBushies
ok, Im figuring on the Black max shocks, where do you guys buy your shocks, and can I get RUBBER body mounts at the same place
I bought them direct from Skyjacker. I like them very much. Coming from Bilstein 5100's, the ride is much much better. I think you will be happy with them
Ok, I decided to go with KYB MonoMax Monotube shocks, they were fairly inexpensive.
and YOUR READING THE LUCKEST GUY IN THE SHOCK REPLACEMENT WORLD. these are the rear upper bolts, that are ( I suspect) 22 years old, and the giant 18" crescents rench in my "metal brake" LOL, to open the lower mounts, worked like a charm.
Its time for lunch and off to do the fronts
Someone who I trust with shock assessments has said they are surprisingly not terrible for a bolt on shock. I wish more would try them, along with the KYB silver bodied shocks.
I have them. They don’t see. Too bad with 33s although I haven’t tried anything else as they came with my jeep.
