2000 Sahara 4.0 Cracked Head
ChappyJeep
Massachusetts
Well, I’m back. The money pit keeps on getting deeper. My previous post was after I replaced the frame, all suspension and steering, etc.
I just finished replacing the radiator, water pump, and thermostat. Denso and Mopar. Now, it seems it’s still not happy with being saved from the scrap yard.
I may have let it get a little hot while I flushed the coolant (was a little low), but not for long at all. The oil came out super milky. First oil change since I got it, not sure how many miles on it.
As far as I’ve read this is likely a cracked head, right? 0331, and no text on in the oil fill valley under the valve cover. I think it also builds pressure on the radiator cap, which I guess I didn’t attribute to a problem. It also drove fine last night, and stayed right below 210.
So basically I want someone to tell me what I already know. Also, is Clearwater still the go to brand for heads (if it was)? Fel Pro gaskets?
Also, do I need to replace my push rods and rockers? I read the guide on here and it lists them. I only have 77k though. Thanks for the advice. When do these become reliable like they say?
Look for antifreeze leaking on the head under the oil cap when at temp. That's where they crack.
Cooling system runs at up to 19 PSI normally.
TUPY casting if you go with a used head
Clearwater head if you want new.
Reactions: John Cooper
Felpro head gasket kit, new head studs, don't forget the sealant on the front one.
If I was pulling a head I'd also do crank and rod bearings, new pistons and rings.
And then you can replace the rear main seal, oil pump and timing chain.
Thanks, I’ll do this tomorrow
Heck, its only got 77K on it. Aint even" broke" in yet. No pun intended :cool:
Reactions: macleanflood
You don’t have to,I would if the the ball imprinted into the rocker arm.
