It appears that whether it's a house or a Jeep , the application of the build clearly needs to be stated . After that the project scope becomes definable .
Presuppositions run wild , and will be used to judge the projects application .
An example would be : Are you using your pickup to drive offroad at 145 m.p.h in Mexico , or are you using it to haul 4500 lbs. of 10 ft. logs 30 miles out of the forest 3 times a week?
We all have bias , and judge others with it . A Trophy truck doesn't haul 4500 lbs. of logs , and logging pickup doesn't run 145 m.p.h on a highway , let alone offroad.
Or another example is someone decides to move a wall and get out a sawzall.
A real Pro looks at it and says man I would not have done that because it was bearing a load.
Or someone walks in a house and says boy this wiring looks neat…
And a Pro walks in and says why in the world did they use the wrong gauge wire?
What guys like me see when they look at a rig like that is big tires, name brands, and aluminum.
What Blaine sees is much different.
He will see things that are there that should not be and things that should be that are not.
He will see things dimensionally that we wouldn’t even begin to guess at the why of.
Real top professionals in every game are at a different level.
