I drive my jeep every day. I have to. Even in the winter. One day I’ll have a house where I can park it and own a daily but for now it is the daily and has to be. So my concern is how to keep the jeep as clean as possible. I have already re done the torque boxes and cut out the frame where the roll bar meets the tub just infront of the rear tire. I have highlined the stock fenders so the torque box is more open and I have removed the rear plastic liner and opened the wheel well so the access to the torque boxes and tub under the tail lights are a lot more open.
Yes I do fluid film and every spring I sand and repaint where I need to. I have noticed that the biggest area that’s getting hit is the torque boxes / slider and the rear bumper/ tail light section. I want to make a little flap of rubber or an aluminum sheet like a mud flap that just blocks off the these areas. How would you do it?
My thoughts are just to add 2 bolts in the back fender wall and add a sheet of aluminum or rubber (what ever I can find) and just extend the fender lower till it blocks the torque box. The rear tail light area is similar since it has a flat pannel blocking the rear access I’ll just extent it. The rear torque box is my concern. I don’t have any real easy spot to mount anything so it would look worst but the principle stands I just bolt a pannel to cover it.
Here is a photo I took today showing how much snow/salt gets in the torque boxes but everything else is pretty good.
What would you do?
What would you do?
