Persistent P0303 on my 2005 TJ — Coil Rail Replaced, Misfire Came Back. What Else Should I Check?
TheManWithNoName
Miami
Hey everyone,
Looking for some advice because this has been driving me crazy.
I’ve got a 2005 Jeep Wrangler TJ (4.0 / manual) that keeps throwing a P0303 (cylinder 3 misfire).
Symptoms
  • Misfire only happens after driving it for a while
  • The car is running rough tho. From time to time, I can feel the car shaking at idle and then it goes back to normal
  • No other codes besides P0303
What I’ve already replaced
  • PCM (a few months ago)
  • Spark plugs (a few months ago)
  • Coil rail (just replaced — Jeep idles smoother but P0303 came back)
My question
Since the misfire is ONLY on cylinder 3 and only shows up when the engine is hot, where should I look next?
Could it be:
Thank you,
Compression and leak down test.
Pull the valve cover and see what the rockers and pushrods are doing.
You also didn't mention removing and inspecting the spark plug on Cyl 3. Could also be a cracked o-ring on the injector for cylinder 3 causing it to go lean. Do you have O2 sensor differences between B1 and B2?
Reactions: TJ Jim and AndyG
Before guessing anymore, swap injectors with a known good cylinder. If the misfire moves, you know it’s a bad injector. If it stays on 3, verify power and control (ground) at the injector plug with a 5 second noid light test. If it’s good, then wrap your injector.
I say this because most of the time it’s heat soak, there’s a P300 associated with the P303, and its usually an issue after shutting it off and cranking it shortly after it’s shut off. Not after “driving it for a while”.
I had the same issue with my 05 last yr after replacing the injectors, heat shields and new plugs. Turned out to be a bad new spark plug. In all my years of replacing plugs I’ve never had an issue with a brand new spark plug. No issues aince.
I agree, sounds totally like heat soak in the Florida sun. I’m in Alabama and fight it too.
I have a friend who contends since they didn’t do it new, that the fuel system loses its ability to hold pressure under intense heat over time, via a weak check valve spring.
Sounds plausible but not proven and guys who have replaced pumps said it did not go away.
I replaced what was left of the OEM heat shielding with a kit from DEI. I bought this,4 hole injectors and new wire pigtails fro K Suspension. I regularly run in the desert heat and never had an issue.
