Just finished installing a 3" BDS list on my. 02 TJ. Does anyone know if the springs will relax after a little use. I ended up with 4" +. Way more lift than I was after.
They're 3 inches longer front and back. What's causing the extra lift is that the new springs are significantly heavier than the originals so they don't compress much under the weight of the jeep. Thanks.
The problem is that my result is 4 inches of lift. I'll have to learn to live with that. I'm sure it's because the new ones are made of heavier wire. .583" vs .5". And 24 years younger. Thanks.
