Never use additives long term. They often fight with the unique addictive packages in the oils. For break in it might be acceptable, but I dunno. Any designed break in oil with flat tapet cams in mind should work fine. I'm a fan on Driven brand products myself, but I won't try to convert anyone.
Don't forget to vary your rpm between 2k-2.5k during initial break in and if you are doing it while parked in neutral, you might consider a fan aimed at the exhaust manifold, especially if it's aftermarket and coated. Consider driving it during break in and alternating between full throttle and max vacuum throttle lifts to help bed the rings.
Many people swear by many different techniques to break in a motor.
