What did you use.
Dawn dish soap and warm water in a spray bottle. Worked it in with a soft brush. Repeated that process twice then used 303.
What did you use.
Dawn dish soap and warm water in a spray bottle. Worked it in with a soft brush. Repeated that process twicd then used 303.
How often do y'all change transmission fluid? 42RLE in my '04 LJ.
My commute takes me up and down the local mountains and my transmission temp gauge hits 180-200 every time, so about 2-5 days a week. I have the Derale external transmission cooler installed as well to help alleviate this a bit, especially in summer. Starting to feel like it's not shifting as well under load.
brighter then high beam when set forward so I may have to point them downwards somewhat to use as fog lamp
I have the KC Gravity® Pro6 LED aux driving lights... they are sick.Took off the front bumper (had to cut one bolt off), sanded rust spots from (apparent) previous light bar and repainted, re-welded nut to frame, and remounted the bumper with new bolts while installing Auxbeam 4 Inch Amber Fog Lights, 60W Square Pod with 5050 LED in lieu of the old crappy square pods (in my profile pic). Also re-threaded a broken sway bar cover bolt and re-installed the cover which has been off for the past 5 months.
First impressions on the Auxbeam spots - brighter then high beam when set forward so I may have to point them downwards somewhat to use as fog lamp (which they are currently wired to). I am planning on getting the KC multi-tab light bar and two 7" chase pods just not sure what to get that is budget friendly. Suggestions are welcome but here are a couple of choices that I narrowed down to:
Auxbeam RAY-L Series 7 Inch
Strands Siberia NR 7 Night Ranger (very limited stock it seams not sure why so a bit leery about ordering these)
Christmas Wishlist choice: KC Gravity® Pro6 LED but money
Removed the rear view mirror, re-soldered the resistor links and got the compass/temp working again.
Did it go out completely? Mine has been going on and off for a while now. Were the links broken or was it bases on experience you knew that was the problem?
Spring is here and summer is just around the corner so time to get my air-conditioning sorted..View attachment 656106
Love that custom rod holder......... er bike rack!
Hand crank?I thought it was his homemade power washer.![]()
Decided to lay out my new Bestop roof in the garage… as the Jeep is getting worked on.
Really pleased to see no Bestop tramp stamp…
Now if I can just time it right and get a day off when the sun is out I can get this thing fitted.View attachment 656119
I'm so sorry you didn't get one with the tramp stamp, now you have to get Bestop tattooed across you lower back instead![]()
