Clutch not engaging, help needed
trident1231
Toronto
Hey guys, I have a 2000 tj. Last night I reversed it, put it in 1st, came to a stop sign, then the clutch felt soft and I couldn't put it in gear(when I tried to push it in, it grinded) i did notice the clutch slightly grabbing quicker the past week or so. When the engines not running I can put it in gear, clutch still feels soft. When I try to start it in gear, the car jumps forward. Im thinking its the master clutch and slave, I did replace my upper steering shaft a few days back, could it be something else?
Any help is appreciated (new to all of this, I bought this tj as a project, it drove fine for the past 2 months)
Remove the clutch master cylinder cap and check the fluid level.
IF the fluid level is normal; the slave cylinder or clutch master cylinder fluid pressure may be bypassing internally.
If the fluid level is low; look for leaks at the slave cylinder and master cylinder back (where the engagement rod pushes on clutch master cylinder).
Reactions: macleanflood
No leaking, fluid was at the right level
IF it doesn’t move enough or at all the clutch master cylinder or slave cylinder are internally bypassing fluid which doesn’t allow pressure to build to move to slave cylinder rod enough to disengage the clutch disc.
