The winter upgrades have officially begun. It was tempting to be coy about this project but that’s not my nature and getting it all out there means I have to get it done or look like a loser. So the plan is :
1) 8” stretch (2” front and 6” rear) to get out to XJ wheelbase at 101”. No comp cut and tank in stock-ish location.
2) Savvy mid arm with Fox 2.0 x 12” coil over suspension.
3) Hi-lines
4) PSC hydro assist steering.
There. I wrote it down. Now I just need to do it by Sand Hollow in May. How do you eat an elephant? One bite at a time…
3 weeks ago,
@macleanflood and I harvested a frame from an 05 junkyard TJ. Work, Thanksgiving and another fire truck issue happened (heater core and blower motor-which I won’t bother detailing except to say that getting those 2 things replaced on a 94 GMC truck is WAY easier than a TJ). Those all delayed starting on the stretch. I got the frame cleaned up and started taking it apart to get what I needed:
The frame was in great shape. Rust belt guys would be pissed at what I paid for it. Zero rust inside. Better than the pretty decent frame on my 97. A shame to cut it up, but cut it up I did. Here are the necessary rear segments cut out and shaved and moved into the garage:
Next, it was time to start on the Jeep. I first ran the tank dry and rolled it into the garage. Next, I took a few measurements to define the starting point with respect to ride height and wheelbase:
Here is the current gap between the rear diff cover and Genright stretch tank skid at full stuff:
Its only 4” and I need 6”. I hope my plan to get 2 more inches works
I have discussed this a lot with
@mrblaine who is a phenomenal resource as we all know. He said start in the front because (if I understood correctly) the ride height is more tightly defined by things you can’t change easily. However, I’m starting in the rear because the benefits of the changes are greater and if I don’t get both ends done by Sand Hollow, I want the rear more. Also
@Fluxor ’s hi-lines with removable flares won’t be ready for a couple of months.
So, the Genright corner armor came off (which I will sell to a forum member for a good price or on marketplace for as much as I can get) and the rear axle came out:
This brings me up to today’s project which was shave the Dana 44. Everthing except the lower control arm mounts came off:
Note the welding curtains and tarp. Thanks to
@sab for the idea. Its gotten chilly and dark as well as intermittently wet out so this has to happen inside. Grinding metal is a giant mess. The barriers worked well however. Most of the debris hits them and falls to the ground. Then it’s pretty easy to sweep it up (see pile next to brackets in 2nd pic).
It feels so good to get going on this
