Cracked block or water pump?
Aiden DeBoo
Roswell Ga
Mechanic said block cracked. 4.0 remafactured from gearhead engine. Is this the block or water pump? And I would like suggestions to prove I didn’t overheat it. I am 100% certain I didn’t. (Mirror showing crank in photo)
Can't tell from those photos to be honest. I don't think you're going to be able to prove or disprove that you didn't overheat it.
Reactions: hear and jeepguy03
I'll be honest it is hard to see from that pic where the crack is, but my first thought about a crack in that area would be someone getting too aggressive during a water pump install.
If it is a reman'd engine, they likely put a heat tab somewhere on the block, which would melt in the event of an overheat.
The block is iron, the water pump is aluminum. So if a magnet sticks to it and it's cracked, it's the blk. If it doesn't it's the water pump.
Reactions: John Cooper
The head bolt requires sealant, but that appears to be the manifold bolt that intersects it.
Yeah I think you are right about that. But, isn’t that head bolt right there in that corner? I couldn’t remember if it was a head, water pump, or manifold bolt. But it is right about there.
