Is generic green coolant okay, or will it cause damage to my TJ?
It makes absolutely no difference what antifreeze you use if you flush and clean the system on a somewhat regular basis. I clean and change mine every 2-3 years. I use the green "all makes and models" Prestone or Walmart brand in all of my Jeeps, regardless of the year. I just cleaned the system on my 03 with a good chemical flush and ran it for several hours, drained it and added the 50/50 Walmart green stuff. I'm still on my original radiator. I bragged about my 99' XJ having the original radiator (21 years old) 6 months ago and it started leaking a week later. I guess I will be buying a new one soon. Karma is a bitch.:(
Karma is for me, too! I started digging around the forum looking for coolant requirements and discovered issues start appearing at 100k. It dropped to -24F this week and I wasn‘t sure if the antifreeze was up to the task of -40F. I popped the hood and saw a little steam rising from the top corner of the radiator where the top tank clamps on. TJ has 99,300 and is right on schedule for issues.
Is there a repair for this or just replace? If I go with new, should I spend extra for the all aluminum or Mopar? Or go with the cheap units with plastic tanks? I don’t need extreme cooling yet also don’t want to replace a radiator every 3 years. I saw single row radiators online. Those are not as efficient at cooling but would they get to operating temps faster in extreme cold? Or is it best not to second guess the engineer’s design?
Yea, you jinxed yourself fer sure! :D But 21 years is at least acceptable, not the 10 that so many hear think is normal. The Mercedes radiator may blow tomorrow for all I know, its one of the very few things that hasn't been replaced or gone through at one time or another. The others are the alternator and PS pump.
Reactions: TheBoogieman
As long as you stick to the same type, I think you will be fine.
Early model TJs (like mine) shipped from the factory with the green coolant in it. I don't think the cooling systems changed from 1997 - 2006.
I have been using the regular old Prestone yellow/green coolant in my Jeep since it was new. My Jeep is now 22 years old and has 150K miles on it. I flush it out and replace it about every 5 - 6 years and I haven't had any problems. I have always mixed it with *distilled* water, and I am still on my original thermostat and water pump!
Yes similar with me.
Reactions: TJRick
Welcome to WTJF. Covid is over now. 🤫 🥳
Nov 4, 2020
In my 04 I drained and filled it several times to make sure nothing was left then used Supertech “Walmart brand” OAT dexcool. This matches my wife’s JK and my F150. I hate having so many different coolants, different oil weights, etc. At least having the same coolant in multiple vehicles makes life easier. The debate will be long and fierce about what kind of coolant (IAT, OAT, POAT, HOAT) to use but essentially your ok if you are 50/50 ratio and not mixing coolants of any different types. No need for flush kits just drain and fill radiator and bottle with water and run and repeat 3-4 times until nothing old is left. Then add your full strength coolant and your done.
You should get a tester. You have pretty close to 70% coolant and 30% water if that is what you were trying to accomplish. If you didn't mean for everyone to use hose water, maybe specify differently.
Good point, a 50/50 mixture is mostly agreed on or even a little heavier in favor of a higher water content. Tap water (hose) really depends on your water source and whether it’s a calcium heavy hard water. Bobtheoilguy.com has tons of debates on this but in my area, Atlanta tap water is just fine (although I still use distilled in the battery).
  • Face Palm
Reactions: John Cooper
I would rather know than debate anyone on the quality of my hose water. If I use distilled, there is no debate. However, if anyone still needs to debate something, I have some oil in plastic bottles and ya'll can wear yourselves out arguing the merits of which color of bottle is best.
The HOAT coolant recommended by Jeep is an ethylene glycol coolant.
Conventional green coolant is also an ethylene glycol coolant.
HOAT type coolant helps reduce deposits and corrosion over the long term and is typically marketed as a long life coolant, frequently with a 5 year flush interval.
The two coolants are compatible, but any long life properties of the HOAT coolant are reduced to the service life of conventional green coolant, which is approximately three years under typical driving conditions.
I wouldn't worry too much about running "conventional green" for awhile. It isn't necessary to throw it out simply because it isn't HOAT. The next time you flush your coolant as part of your regular maintenance schedule you can buy a HOAT coolant like Zerex GO5.
In the meantime you can top it off with conventional bright green coolant. If you have any concerns that the green stuff in your radiator now isn't ethylene glycol, then just top off with distilled water rather than use any coolant at all. There's nothing magic about a 50/50 ratio. In areas that get super cold that ratio may be necessary in the dead of winter but in warmer climates a 60/40 ratio is just fine. In some sports car circles, owners from Arizona and other very hot places advocate a 65/35 ratio of water to coolant during summer because the antifreeze properties are not necessary, there is still enough lubricity for the water pump and other cooling system parts in a 65/35 mix, and plain water actually cools better than coolant.
50/50 O’Reilly green for me.
