I love how the paint scheme on the camper makes it look like you have a pickup with a bed camper loaded up to go.
One of the first things I did was pull all the vinyl decals with the branding off of the RV. The only thing I couldn't get off was that one black stripe with Grand Designs because it was from the front cap to window and under the silicone on each end.
I ordered it through Amazon, just so I could track shipping..... does that count???? 🤷‍♂️ 🤷‍♂️ :ROFLMAO::ROFLMAO:
Got confirmation the Savvy cable shifter is out for delivery !!
So in anticipation of removing the entire Tcase skidplate I bought a new creeper.
I wanted one that the headrest adjusted on and it even matched my toolbox :cool: :cool: :cool:
Ok got the Savvy shifter installed, just need to tune it a little bit more for 4 low and its done.
Will take some pictures tomorrow when I finish it up.
Ordered a transmission mount because mine is ripped, probably from where I let the skidplate down to fast.
Gonna finish cleaning up the skidplate and bottom of the frame (no rust just dirt) and repaint both before I put it back together.
Got the last of the quarter century old suspension out of the TJ.
JKS J-Flex upper CAs front and rear. Did the lowers previously. Everything... I mean EVERYTHING has been replaced at this point. Jeeps rides super tight and handle fantastic.
Now the task of deciding on new tires. The Falken Wildpeak AT 3Ws have about 60k miles on them and still have about 9/32 of tread left. Still dead quiet. Great in the dry, better than okay in the snow but absolutely suck in the wet. Undecided on which tire though. KO2s are at the top of the list.
Started on replacing the very last of the original suspension parts - the rear trackbar. Got as far as getting the LH rear LCA, UCA, swaybar link, shock, wheel, spring, jounce bumper off, and the nuts removed on both ends of the trackbar. I couldn't get the axle to quite droop down enough, not even by lifting on the other end, so I used a bottle jack and pushed it down the last inch or so. That T-55 bolt is as ridiculous as everyone says it is, so I didn't even bother trying to deal with it without an axle drop. I put about 2 feet of extension on, and got it loosened up with my impact. I generally don't like using an impact on something like this - can be too much chance of galling or breaking something, but as I got it to turn with a breaker bar first, I decided to risk it. Getting the frameside nut off was fun - lock nut with no room to ratchet, but got it off eventually. Now I just need to get the two bolts out, hopefully jacking the axle back to level will make that easy(er).
In other words, thus far no more than the usual nuisance.
When I did that a few years back, there was some surface rust on the frame. I bought some grade 8 washers and put just enough to get a small gap between the skid and frame.
I had an oil leak on my valve cover gasket and seepage from the rear valve cover crankcase vent, so it was time to change it. With help from the forum I was able to find the part numbers for the gasket, grommets and replacement elbows.
I took my time, being retired, I’ve learned to take a break when you need one.
There was a lug in the back drivers side and a bracket that holds the AC line that were just big enough to keep the valve cover from coming off, once I figured that out, and pulled them off, the valve cover came off easily. The rear valve cover bolt was loose, likely the cause of the leak.
I think I spent as much time cleaning the valve cover, bolts and replacing the grommets and the elbows. The rear elbow had always had some oil around the top of the valve cover.
I started on the front elbow, and after breaking the flange off, I pulled out the box cutter. That front grommet was hard as a rock! When I finally got the front elbow out, after cutting it apart, I started to pull the rear elbow. It came out surprisingly easy. The old elbow I took out was slightly small diameter than the new one. So the oil leak from that grommet should be fixed.
I put everything back together, no leaks!
I spent sometime cleaning the top of the block, it had some nasty oil and dirt caked on it.
Next on the agenda is to degrease the back of the engine. I bought some Gunk heavy duty degreaser and some Autozone degreaser. Hopefully between the both of them i can get it cleaned up.
I think I will be replacing the heat shield blanket on the intake manifold. Not sure if I should use the DEI set up or just replace it with the Mopar part. Any suggestions?
Roses are red...
Violets are blue...
I fixed my Jeep...
Its as good as ne - WHAT THE %#(*!{]\ NOW?!?
I got the new rear trackbar in place, and bolted down. Getting the new bolts to line up was a PITA - did the axle end first, no problem. Frame end wasn't bad either - I just jacked the driver's side up and down until the hole lined up...
BUT...
Getting that bolt all the way through was the PITA. Ended up using a pipe wrench (!!) on the track bar to twist it until the other hole lined up, and it took me and a neighbor to get the damn thing done. The rubber bushings, of course, are designed to deal with the twist, BUT all the twist had to take place in the axle end bushing until that bolt was all the way through - if that makes sense...
Anyway, that's done. I even got the passenger side shock bolted back in place, tomorrow I'll do the driver's side UCA, LCA, shock, spring, jounce bumper, vent tube, and wheel/tire. At least I've done those before - I might have to pull the axle forward a bit with a come-along, we'll see.
