As they say, "Two is one, and one is none"...
https://bringatrailer.com/listing/1976-gmc-26-palm-beach-motorhome/
STOP IT!!!!
Now that I've lined you up with a support group for your shock-rebuilding affliction, here's a test. Like setting a shot in front of an alcoholic...STOP IT!!!!
You know, I do remember a little disagreement on the color and if a T/A style bird could be applied to the side. Seems like an easy solution.
When
When i worked in a body shop my boss cussed whenever we talked about those huge emblems. Apparently they were expensive and a real pain to get lined up on the hood correctly
Now that I've lined you up with a support group for your shock-rebuilding affliction, here's a test. Like setting a shot in front of an alcoholic...![]()
Alas, I live in town with a 1/4 acre lot and no place for extra vehicles.
Man, everyone is just full of good ideas today!
Been working on the dash cover and its almost done. Gotta finish gluing to the bezel. Going through the rest of my parts to finish the dash resto-mod, I noticed that one of my HVAC vent deflectors was broken...The adjustment flap was moving around vs moving all the parts and one of the pins that hold the whole deflector assembly was broken off. I modeled it up and printed them out.
After LOTS of trial and error, I just couldn't get the vent assembly back together. Not sure how it was done at the factory but I couldn't get things stable enough to reassemble.
So, because you can make things with a 3d Printer that you can't do with some other methods...I made an assembly that captures the little bar that pivots the deflector flaps (that was the issue trying to reassemble) and printed it out.
Circled is the "plug" to capture the link bar.
And the assembly
Giving enough clearance (I think I did 0.010 on the diameters) I printed the whole thing and once it was done, the link bar is now captured on the deflectors and it pivots perfectly. I don't currently have any pictures...Have to grab one later.
