Exactly why I always recommend a 14k trailer. They are not much more than a 7k and will give you anywhere from 10-11k of cargo capacity. The 14k one I sold in the spring weighed in at 2,600#. I bought it new early fall 2024 for $5,200 OTD delivered.A 7k would likely work for most.
But a 7k trailer, factor in the weight (~1500lbs), and you're limited to 5500 lbs +/-. of hauling capacity, that is almost 80% of the trailers limit.
A TJ is somewhere around 4k lbs, add your tools, your coolers, anything else, that 1500lb of available capacity can diminish fast.
Just setting here thinking that the short just enough length trailer for a TJ will not allow you to move the TJ around on the trailer adjusting the tongue weight. A 18'+ trailer would allow you to move the TJ back to take weight off the tongue of the truck/SUV pulling it.
I've been running this trailer for 10 years. It's a 2015 custom-built Kaufman 20' / 10k, with a 102" wide deck, no dovetail, and drive over fenders which I built. I've also done a custom tongue lock, custom ramps with an expanded metal deck which allows me to easily pull the motorcycles on, and a vice mount on the fenders. It's been a fun project. The box contains something like 1000 pounds of spare parts, tools, fluids, jacks, and such.
With the rig on it, it tips the scales at 10,600 pounds...
And despite running 14 ply / G rated Carlyse tires, it blows tires with regularity - usually when making the trip to Moab at 80. It's simply overloaded.
So I've now ordered a new custom Kaufman Deluxe. Same 20 ft, 102" width, drive over fenders (which I'm reluctantly having them build), but a 15k pound, 8 lug beast. For reference in the context of this thread, the build cost at about $8,600.
Should be done in 2 or 3 weeks, at which point I'll make the trek over to SC to pick it up.
Other than my capacity issue, I love this thing and am sorry to be giving it up. It would work well for anyone towing a normal Jeep - just not the 6400 pound pig I drag around...![]()
Where did you get the bolt down wheel chock?I've been running this trailer for 10 years. It's a 2015 custom-built Kaufman 20' / 10k, with a 102" wide deck, no dovetail, and drive over fenders which I built. I've also done a custom tongue lock, custom ramps with an expanded metal deck which allows me to easily pull the motorcycles on, and a vice mount on the fenders. It's been a fun project. The box contains something like 1000 pounds of spare parts, tools, fluids, jacks, and such.
Then you will overload the deck. If you have an accident they will look at the rating on the manufacturer sticker. That can bite you in the rear.I was givin a 7k car hauler but was going to just buy a couple 5k or 7k axles to swap out to give me a little more capacity on the trailer just case?
