6" is definitely not required on a GMT800 for 33s. A Suburban will accommodate that with a torsion bar crank.
6" on an IFS is going to play hell with the drive line angles. Dropping the differential without rotation to keep the CV axles happy will likely require DC joints on the front driveshaft. 6" just at the suspension (spindles/springs) is going to kill the axle CVs. Splitting the difference is going to make all the angles bad.
From a quick search, quite a few manufacturers make 6" lifts for the IFS trucks but I suggest reading the installation fine print about front driveline modifications.
For extra clearance on 33s, may I suggest 2" keys up front and a 1.5" rear coil spacer.
