Don't take this as picking on you because it isn't. You mentioned "properly rated" several times. What does that mean in your recovery use world?
What information do you want to see on a rating tag?
On the rigging side, you rarely see Max Breaking Strength (MBS) tagged. You occasionally see the better recovery equipment list a second number, Working Load Limit (WLL) (sometimes listed as rated capacity) which is the only thing we use in rigging. This is the designed repeat use strength of the part, and is normally the MBS reduced by a Factor of Safety determined by an engineer. The FoS is normally some ratio greater than 4:1.
I grabbed a couple shots back in the shop, attached here.
As much as possible, I try to apply the same logic in recovery. Although they're proud of their stuff, at least F55 labels their items. For example, the Flatlinks I use on the Jeep are stamped with 16k capacities with MBS over 40k. Their "standard" 7/16 soft shackle has a WLL of 7,800 lbs and MBS of 39,000 lbs (there's that FoS of 5:1).
IIRC, even the reputable manufacturers use a lower 2:1 factor of safety when they rate winch line. For example, I think 3/8" Dyneema has an MBS of around 18k and is preloaded on even a Warn VR Evo 12-S.
It's always important to properly use the equipment as well, as you can see on the Crosby shackle pictured above, they've marked the 45*. Just going to 45 reduces WLL by 30%.
When I originally heard the name Factor 55, I assumed it was from them using a FoS of 5.5, I later learned listening to an interview it had nothing to do with that, unfortunately.
