Today I worked on fixing an issue I’ve had with my Coyote beadlocks. I really like the Coyote set up because:
1) it is light weight at +6# per wheel.
2) locks both beads.
3) the inner high pressure tire stands about 3 inches off the rim so the set up works as a complete run flat if need be.
4) the entire cost for the set is about the same as one traditional bead lock rim, which is another bonus.
However, there is no protection for the rim’s stock valve stem and I have managed to rip one off twice. The first time was a legitimately tough spot. I was struggling to get up winch hill one on Fordyce. The second time was random. I was just driving along on Cliffhanger. The run flat idea would work in a pinch but would likely trash the tire. So, on both occasions, I put in a Colby emergency valve stem and finished the day without issues. But to avoid the problem, I decided to try moving the stock valve stem for the outer tire to a more protected location. Here is my original configuration:
You can see how exposed the stock valve stem for the outer/low pressure tire (chrome cap) is compared to the inner tire valve stem (red cap). To move it more centrally, I needed a new hole and a longer air channel as well as a way to plug up the old hole. I decided to try this with my spare before committing to all five. Here’s the rim with three holes in it:
The overlap of the nylon tread of the inner tire is significant and adds about 100 g of weight eccentrically (that’s about 3.5 oz. for @JMT
). The new air Channel is 7 inches long instead of the original 5 inches and weighs about 60 g.
The innertube valve weighs about 20 g and my solution for plugging the stock valve hole is about 10 g. So all of that is placed on the opposite side of the rim from the nylon tread overlap to help with balance. While milling around the nuts and bolts isle at the CO-OP, I happened upon some rubber grommets with 1/4-20 nuts inside (not sure what they’re called, edit: they are well nuts. Thx
@sab) that, combined with a short 1/4-20 chrome cap bolt and washer, seemed a promising solution for plugging the original valve hole:
Even though it’s pretty smooth and low profile, I put a square of gorilla tape over it to protect the inner tube and help with sealing.
Also for additional air seal, I put plumbers tape on the bolt.
Then I put it all back together:
Much lower profile/more removed from harm’s way
If it holds air and balances OK, I think it may solve the problem
(edit: 2 weeks later and both chambers without leaks).
