Sport cage bolt to wheel well - opinions
I believe the 6 turns comes from wheel spacer installations with covered lug nuts. Agree with your resulting concerns there, and it's likely not a good source for safety minimums.
That's a very bad rule then. 1/2-20 is the size and pitch. 6 full turns is slightly more than a 1/4 of an inch or about .300" and that's not comfy.
Reactions: GATORB8
IIRC, in construction the requirement is that the bolt be at (or past) flush with the end of the nut.
The ASME reference in MrBlaine's snip is the nut spec which standardizes the depth/thickness of the referenced nuts. But that is dependent on the nut material since the goal is the fastener fails before the nut fails, so thickness could be different on a weldnut.
I'd say the safest route would be to match or beat the grade of the fastener, and purchase one at least the additional length of the material that was added. If the original fastener is flanged, and a hex head is used instead, addition of the washer should also be added to minimum length.
The 30 lb-ft is maxing a dry-set 3/8-16, so I'd expect to go grade 8:
Or, like I posted already, stick your head under and take a peek at it. If you can see threads, you're golden. If not, fix it. Why are we guessing?
Reactions: GATORB8
100% agree. I actually don't see it from a manufacturer, but guess where I do see it:
Reactions: mrblaine
And again, if we don't know the pitch, then we don't know what 6-8 turns gives us for engagement. 1 1/4-12 gives us 12 threads per inch, 6 turns is a half inch and that's not gonna work. I would guess for lug nuts in 1/2-20, I'd want at least 10 to get a 1/2" of engagement given what we do to our tires offroad. It is a bit more than a common nut will give us but not by much. Or I'm just being cautious having been around a few folks that lost wheels on the highway.
Reactions: GATORB8
That was the exact application.
Reactions: GATORB8
If this was a problem I was worried about, I'd just peel back the fender liner and take a peek to see if any threads are sticking through the weld nut. No? Get a longer bolt. Yes, good to go.
and this right here is the bottom line. If the bolt is fully engaged, gtg.
I think a big part of why this forum is because mrblaine doesn't let anyone get away with dropping answers in threads because its what a bunch of other people on the internet said. requiring empirical or at least logical evidence that the solution is in fact correct and helpful.
also, re: wheel spacer install instructions, this is in the instructions from the site I bought my adapter/spacers from:
I thought they had thread pitch on the sae studs but I guess they are assuming "standard" pitches for the sae sizes.
Hard to go wrong doing it that way.
Logic, critical thinking and a smidgen of common sense go a long way toward helping folk understand the why of things. If the why was understood even a tiny bit, no one would ever say that 6 turns is a recommendation without a qualifier. I hope at some point the poor guy I offended so much realizes that it wasn't so much his error I was picking on as I was Mac for liking it. Don't encourage him Mac, accuracy is a good thing.
That said, who ever did this guide below, needs to explain what rule their math is following. That and the jump from the 1/2" torque value when it goes to 9/16 is monstrous for only a 1/16" increase in diameter.
mystery to me, especially since 9/16" is so close to 14mm (0.551" vs 0.5625") I only cared about what they wanted me to torque my 1/2" lugs to, as well as the thread engagement, which made it abundantly clear that the shorter pilot point studs that came with my axles, while great for being able to install or remove without pulling the axle shaft out, were short by a few threads for full engagement of the lug nuts (i think i had 5.5 turns. Longer studs got it to where it needed to be, which was coincidentally enough to run threads through the whole nut.
That chart is strange. Typically a fine thread fastener will have a higher torque value in the same grade due to a slightly larger root diameter at the threads than the coarse version. They don't make that distinction with their 14mm stuff and as you said, 14mm and 9/16 are practically interchangeable but have dramatically different torque values. If I knew a value for 9/16" wheel studs, I'd certainly have used it on 14mm studs. It would be nice to know if I'd have made a mistake by doing so.
