Sport cage bolt to wheel well - opinions
Hey all, just looking for an opinion on this. On my 2001 Jeep TJ I have the MORryde tailgate reinforcement kit, which connects through the jeep body to the inner sport cage bolt on the passenger side of the jeep. I've had that on my Jeep TJ for a few years and it's held up solid.
I recently just added the Hooke Road interior cargo rack (https://www.hookeroad.com/collectio...-97-06-wrangler-tj-interior-cargo-rack-b1029s). I didn't realize it until I started installing it, but it also reuses the same exact bolt as the MORryde reinforcement kit.
I have it installed, and was able to torque the bolt down to 30 ft, but this has taken maybe 1/8th to 1/4than inch off that sport cage bolt. Is this a problem, or should I seek a longer bolt?
pics for reference:
The rule is if you can get 6 full turns you have good engagement.
The rule I heard was at least 1.5 times the fastener diameter in thread engagement. Though that screw is going into a welded nut so it should at least go deep enough to occupy all of the nut threads.
Reactions: lBasket
I think you are probably right that there is enough thread engagement. I'm just a nervous Nelly.
I measured it and it is about 1/4th of an inch extra space.
It was cheap and easy enough for me to find a 3/16-8 x 1.5" grade 8 bolt and washer, so I did put a slightly longer one in for peace of mind.
The stock one is 3/16-8 x 1.25" for future reference.
I can't tell which is more retarded, your bolt sizes or Mac liking your post. There is no such thing as a 3/16-8 bolt. Closest to that is 10-24 which is close to 3/16" in diameter.
There are lots of rules about thread engagement. However, there is not a single standard nut that follows any of them. Look at the heights relative to thread diameter.
Then we have all of us running control arms that adjust with jam nuts which are even shorter and we've never stripped one nor do I know of anyone who has.
If this was a problem I was worried about, I'd just peel back the fender liner and take a peek to see if any threads are sticking through the weld nut. No? Get a longer bolt. Yes, good to go.
3/8-16 I speak dyslexic.
And I speak I can't find my readers so I'm trying to respond...but...
So you'd run a 1 1/4-12 Johnny Joint shank threaded into the control arm 1/2" and call it good?
I may have written that spec for a specific bolt, and therefore it is incorrect for many other applications. I’ll happily delete my post. Thanks for calling me out.
IIRC, in construction the requirement is that the bolt be at (or past) flush with the end of the nut.
The ASME reference in MrBlaine's snip is the nut spec which standardizes the depth/thickness of the referenced nuts. But that is dependent on the nut material since the goal is the fastener fails before the nut fails, so thickness could be different on a weldnut.
I'd say the safest route would be to match or beat the grade of the fastener, and purchase one at least the additional length of the material that was added. If the original fastener is flanged, and a hex head is used instead, addition of the washer should also be added to minimum length.
The 30 lb-ft is maxing a dry-set 3/8-16, so I'd expect to go grade 8:
Reactions: reddvltj
If you are following a rule that the spec is correct for, what is that rule? How many threads per inch do we have to have before that rule we are trying to adhere to applies? What thread pitch do we need before 6 full turns actually works?
Not sure what is "retarded" about mixing numbers up in a bolt size. Some of us are amateur mechanics and amateur forum members, not sitting around thinking about bolt sizes and grades all day. I left the information in case someone comes back around looking for the same information and finds it, since I have searched up and down in this forum and wasn't able to find it, but I found it on other Jeep forums. I even posted a picture of the parts list. Not sure what is low fucking effort about that.
Low effort is not proofing and making sure it is correct so that others benefit from your experience and knowledge. Has nothing to do with how much you sit around thinking about anything but more instead assisting those that needed the same info you needed only you couldn't take the time to make sure it was right. Gibberish is gibberish whether it is rules or numbers and again, numbers you really wish were there just to make things a tiny bit easier.
Been a member of this forum a long time, it has been a life saver only ever have tried to be a good contributing member,
Well then, do that. Check your work so others can benefit. It isn't a contribution if it is all fucked up and retarded.
and this is the shittiest response I've gotten from someone.
Deservedly so.
Regretting ever buying your brakes, fuck right off.
If you are really that fucking delicate, take them all off and send them back, I'll happily refund your money. Or, you can recognize you need two things, good brakes and a level of accuracy that is actually helpful.
I believe the 6 turns comes from wheel spacer installations with covered lug nuts. Agree with your resulting concerns there, and it's likely not a good source for safety minimums.
